So you had inadvertently enabled this feature, so the Gemfile is used for both vscode (rubylsp) and the jrubyscripting addon. You don’t want to have gem "rubocop" for your normal jrubyscripting scripts. That’s what caused the errors in your openhab logs: jrubyscripting is trying to install the rubocop gem which depends on prism.
As to why your rubylsp / rubocop is playing up that’s probably a separate issue.
In any case, I’d suggest moving your Gemfile for RubyLSP and .rubocop.yml files to ~/conf - assuming that is the root of your vscode workspace. Also I’d suggest adding ~/conf/.ruby-version that contains:
3.4.6
Or whatever is the latest version in 3.4.x
and set your rubocop to TargetRubyVersion: 3.4, because in openhab 5, jrubyscripting addon uses jruby 10.x which supports ruby 3.4 compatibility. But using 3.1 in rubocop / .ruby-version is fine too if that’s what you prefer.
You should install ruby-3.x (i.e. mri, matching your .ruby-version and rubocop) using rbenv. This will be for rubylsp only. It won’t affect jrubyscripting which will use jruby shipped / bundled with the addon.
If you want to use Gemfile for jrubyscripting, you can put that in ~/conf/automation/ruby.
thanks again for your help. I’m still struggling with UoM. I have a timeseries of type Number:EnergyPrice enforced by the binding it creates. That unit is breaking all my attempts on processing the timeseries. Is there any way to get rid of it? I don’t need it. I tried using numeric_state somehow, but it’s not working.
2025-10-05 19:45:43.685 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID '44c808bd42' failed: javax.measure.UnconvertibleException: javax.measure.IncommensurableException: EUR/kWh is not compatible with one
Too early… Error is still there, I just did not recognize it. I tried to bring openHAB into a “as clean as possible” state when it comes to JRuby. No success. Neither do I have an own Gemfile anywhere in the openhab conf subfolders nor are the VSC extensions for Ruby LSP or rubocop installed. I stopped the openHAB Docker container, removed the “.gem” folder inside ./openhab/conf/automation/ruby and restarted the openHAB container resulting in the following two errors: [ipt.internal.ScriptEngineManagerImpl] - ScriptEngine for language 'application/x-ruby' could not be found for identifier: e95531a6-0463-4003-8edf-fb651c5ac166
and
org.jruby.exceptions.StandardError: (InstallError) Gem::Ext::BuildError: ERROR: Failed to build gem native extension.
current directory: /openhab/conf/automation/ruby/.gem/10.0.0.1/gems/prism-1.5.2/ext/prism
/usr/lib/jvm/java-21-openjdk-amd64/bin/java -cp /openhab/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.4.7.jar:/openhab/runtime/lib/boot/org.apache.karaf.jaas.boot-4.4.7.jar:/openhab/runtime/lib/boot/org.apache.karaf.main-4.4.7.jar:/openhab/runtime/lib/boot/org.apache.karaf.specs.activator-4.4.7.jar:/openhab/runtime/lib/boot/osgi.core-8.0.0.jar:/openhab/runtime/lib/jdk9plus/istack-commons-runtime-3.0.12.jar:/openhab/runtime/lib/jdk9plus/jakarta.xml.bind-api-2.3.3.jar:/openhab/runtime/lib/jdk9plus/javax.annotation-api-1.3.2.jar:/openhab/runtime/lib/jdk9plus/jaxb-runtime-2.3.9.jar:/openhab/runtime/lib/jdk9plus/org.apache.servicemix.specs.activation-api-1.2.1-1.2.1_3.jar:/openhab/runtime/lib/jdk9plus/txw2-2.3.9.jar org.jruby.Main extconf.rb
extconf failedBad file descriptor - /bin/sh
Gem files will remain installed in /openhab/conf/automation/ruby/.gem/10.0.0.1/gems/prism-1.5.2 for inspection.
Results logged to /openhab/conf/automation/ruby/.gem/10.0.0.1/extensions/universal-java-21/3.4.0/prism-1.5.2/gem_make.out
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/rubygems/ext/builder.rb:103:in 'run'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/rubygems/ext/ext_conf_builder.rb:30:in 'build'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/rubygems/ext/builder.rb:195:in 'build_extension'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/rubygems/ext/builder.rb:229:in 'block in build_extensions'
org/jruby/RubyArray.java:2079:in 'each'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/rubygems/ext/builder.rb:226:in 'build_extensions'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/rubygems/installer.rb:844:in 'build_extensions'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/rubygems_gem_installer.rb:111:in 'build_extensions'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/rubygems_gem_installer.rb:30:in 'install'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/source/rubygems.rb:205:in 'install'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/installer/gem_installer.rb:55:in 'install'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/installer/gem_installer.rb:17:in 'install_from_spec'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/installer/parallel_installer.rb:133:in 'do_install'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/installer/parallel_installer.rb:124:in 'block in worker_pool'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/worker.rb:62:in 'apply_func'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/worker.rb:57:in 'block in process_queue'
org/jruby/RubyKernel.java:1658:in 'loop'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/worker.rb:54:in 'process_queue'
uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/worker.rb:90:in 'block in create_threads'
An error occurred while installing prism (1.5.2), and Bundler cannot continue.
In Gemfile:
rubocop was resolved to 1.81.1, which depends on
rubocop-ast was resolved to 1.47.1, which depends on
prism
at RUBY.handle_error(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/installer/parallel_installer.rb:167) ~[?:?]
at RUBY.call(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/installer/parallel_installer.rb:97) ~[?:?]
at RUBY.call(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/installer/parallel_installer.rb:66) ~[?:?]
at RUBY.install(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/installer.rb:198) ~[?:?]
at RUBY.run(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/installer.rb:84) ~[?:?]
at RUBY.open_file_with_flock(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/rubygems.rb:828) ~[?:?]
at org.jruby.RubyIO.open(org/jruby/RubyIO.java:1284) ~[?:?]
at RUBY.open_file_with_flock(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/rubygems.rb:816) ~[?:?]
at RUBY.open_file_with_lock(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/rubygems.rb:802) ~[?:?]
at RUBY.lock(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/process_lock.rb:13) ~[?:?]
at RUBY.filesystem_access(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/shared_helpers.rb:105) ~[?:?]
at RUBY.lock(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/process_lock.rb:12) ~[?:?]
at RUBY.run(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/installer.rb:71) ~[?:?]
at RUBY.install(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/installer.rb:23) ~[?:?]
at RUBY.gemfile(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/inline.rb:64) ~[?:?]
at RUBY.temporary(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/settings.rb:159) ~[?:?]
at RUBY.gemfile(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/inline.rb:63) ~[?:?]
at RUBY.gemfile(uri:classloader:/META-INF/jruby.home/lib/ruby/stdlib/bundler/inline.rb:58) ~[?:?]
at RUBY.<main>(<script>:6) ~[?:?]
ChatGPT could not help me out that’s why I am here again.
Thanks!!! That did it! Interesting, the only occurance of rubocop was in ./openhab/userdata/config/org/openhab/automation/jrubyscripting.config and gems=“openhab-scripting=~>5.0,rubocop”.
No idea how it got there. Removing it and restarting it finally made the error go away. The only booting error I see is this: [ipt.internal.ScriptEngineManagerImpl] - ScriptEngine for language 'application/x-ruby' could not be found for identifier: e625164f-5f28-418d-8382-232bcd869007
I cannot grep any e625164f-5f28-418d-8382-232bcd869007on the whole openHAB file system. I mean, I can live with it, but do you have any idea where this might come from?
If you configured it from file, check conf/services/jruby.cfg. If you configured it using the UI then check the UI settings.
It’s probably a managed rule / script / transformation, or an inline transformation script. The error / warning can probably be ignored. The rule got loaded before the jrubyscripting addon loaded.
I have a rule warning me when a specific thing turned offline:
rule "Steckdosen: Balkonkraftwerk ist offline" do
changed things["shelly:shellyplusplug:<ID>"], from: :online, to: :offline, for: 1.minute
run do
# Some foo stuff...
It triggers as expected, but it also triggers when the Shelly binding tries to find the plug in the network and fails. Check out this event.log entry:
2026-02-04 11:40:30.050 \[INFO \] \[ab.event.ThingStatusInfoChangedEvent\] - Thing ‘shelly:shellyplusplug:<ID>’ changed from ONLINE (CONFIGURATION_PENDING): Gerät wird initialisiert oder im Schlafmodus. to OFFLINE (COMMUNICATION_ERROR): Verbindung zu Gerät fehlgeschlagenh: NoRouteToHostException: No route to host
The rule should only fire when something like this happens:
your 2026-02-04 11:35:16.188 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:<ID>' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Das Gerät antwortet nicht und scheint nicht mehr verfügbar zu sein.code goes here
Can I check more fine granular the type of “online”?
only_if { |event| event.was.status_detail == org.openhab.core.thing.ThingStatusDetail::NONE }
# or alternatively
# only_if { |event| event.was.status_detail.to_s == "NONE" }
run do
# Some foo stuff...
