Here you can find the console output when I installed JRule from the marketplace. No errors.
I can try to reproduce this on my openHAB instance earliest around the 20th.
I appreciate it!
After reverting to OH 4.1.3, I discovered that the console output after installing JRule on OH 4.2.0 is missing the following lines:
21:49:04.755 [INFO ] [n.jrule.internal.handler.JRuleHandler] - Instantiated JRuleActions class
21:49:04.761 [INFO ] [jrule.internal.compiler.JRuleCompiler] - [JRuleCompiler] Found no classes to load into memory in folder: /etc/openhab/automation/jrule/rules
21:49:04.765 [INFO ] [jrule.internal.compiler.JRuleCompiler] - [JRuleCompiler] Found no user defined java rules to load into memory in folder: /etc/openhab/automation/jrule/rules-jar
21:49:04.773 [INFO ] [n.jrule.internal.handler.JRuleHandler] - [JRuleHandler] JRule Engine Initializing done!
******** Loaded 0 rule classes, change 0
******** Loaded 0 rule methods, change 0
******** Loaded 0 item state triggers, change 0
******** Loaded 0 channel triggers, change 0
******** Loaded 0 timed triggers, change 0
******** Loaded 0 thing triggers, change 0
Uploading the pre-compiled JAR to the right folder on OH 4.1.3 triggers JRule to load it immediately.
Are your rule classes in the correct package? Ran into a similar issue where rules would not get loaded because I put them in my own package. You need to put them into org.openhab.automation.jrule.rules.user
or add org.openhab.automation.jrule.package=your.package
into jrule.conf
Yes, the rules are under
They are the same rules I was running with OH 4.1.3, just they didnāt work right after I upgraded to 4.2.0.
What I think the issue is (check my previous comment), is that JRule is not fully loaded. Iāve no idea what is blocking it. I donāt know what log would report the issue, as I donāt see anything in the standard ones.
Good lead is that
Is missing in 4.2.1. I did not check the source code, but before this and after
Instantiated JRuleThings class
I expect something to be loaded (dependency or something) that is not there.
This shows that it is very lickely not related to the rule, but binding/dependency/framework related.
Itās odd that the problem is related to the binding/dependency/framework, keeping in mind @Seaside 's comment:
@lsiepel, did you install JRule on OH 4.2.0 and have the same problem?
Iāll be able to check Sunday or Monday.
Downloaded the BETA21, dropped it in the addon folder and all seems fine:
2024-08-20 10:18:47.160 [INFO ] [on.jrule.internal.engine.JRuleEngine] - [JRuleEngine] Initializing Java Rule Engine with Separate Thread Executors min: 2 max: 10
2024-08-20 10:18:52.389 [INFO ] [tomation.jrule.internal.JRuleFactory] - [JRuleFactory] Initializing Java Rules Engine v4.0.0.202404081933
2024-08-20 10:18:52.390 [INFO ] [.jrule.internal.handler.JRuleHandler] - [JRuleHandler] Initializing Start Initializing JRule Automation
2024-08-20 10:18:52.395 [INFO ] [.jrule.internal.handler.JRuleHandler] - [JRuleHandler] Initializing JRule writing external Jars: /etc/openhab/automation/jrule/jar
2024-08-20 10:18:52.397 [INFO ] [.internal.compiler.JRuleJarExtractor] - [JRuleJar] Extracting jar: /etc/openhab/automation/jrule/jar/jrule.jar to: /etc/openhab/automation/jrule/jar/jrule.jar
2024-08-20 10:18:52.415 [INFO ] [.internal.compiler.JRuleJarExtractor] - [JRuleJar] Extracting jar: /etc/openhab/automation/jrule/jar/openhab-core.jar to: /etc/openhab/automation/jrule/jar/openhab-core.jar
2024-08-20 10:18:52.805 [INFO ] [.jrule.internal.handler.JRuleHandler] - [JRuleHandler] Compiling generated sources
2024-08-20 10:18:58.374 [INFO ] [.jrule.internal.handler.JRuleHandler] - [JRuleHandler] Creating jrule-generated.jar
2024-08-20 10:18:58.608 [INFO ] [.jrule.internal.handler.JRuleHandler] - [JRuleHandler] Compiling rules
2024-08-20 10:18:58.612 [WARN ] [rule.internal.compiler.JRuleCompiler] - [JRuleCompiler] Found no java rules to compile and use in folder /etc/openhab/automation/jrule/rules/org/openhab/automation/jrule/rules/user/
2024-08-20 10:18:58.626 [INFO ] [rule.internal.compiler.JRuleCompiler] - [JRuleCompiler] Number of classes to load in to memory: 101 folder: /etc/openhab/automation/jrule/gen
2024-08-20 10:18:58.740 [INFO ] [.jrule.internal.handler.JRuleHandler] - Instantiated JRuleItems class
2024-08-20 10:18:58.743 [INFO ] [.jrule.internal.handler.JRuleHandler] - Instantiated JRuleThings class
2024-08-20 10:18:58.745 [INFO ] [.jrule.internal.handler.JRuleHandler] - Instantiated JRuleActions class
2024-08-20 10:18:58.746 [INFO ] [rule.internal.compiler.JRuleCompiler] - [JRuleCompiler] Found no classes to load into memory in folder: /etc/openhab/automation/jrule/rules
2024-08-20 10:18:58.747 [INFO ] [rule.internal.compiler.JRuleCompiler] - [JRuleCompiler] Found no user defined java rules to load into memory in folder: /etc/openhab/automation/jrule/rules-jar
2024-08-20 10:18:58.750 [INFO ] [.jrule.internal.handler.JRuleHandler] - [JRuleHandler] JRule Engine Initializing done!
So now iām confused, there must be something specific to your setup that prevents this rule addon to load correctly.
Note that i have no rules setup.
I guess we need to remove parts of your setup to determine the cause.
Do you have other addons installed? Could you list them and/or temporary uninstall them, to be sure there is not something else
Have you made any changes to configuration files in the userdata folder?
Huh, those are not good news
Letās start with the basics. I upgraded to OH 4.2.0 stable from 4.1.3 using dnf, as Iāve done since 2.X.
OH runs with OpenJDK 64-Bit Server VM (Red_Hat-17.0.6.0.10-3.el9) (build 17.0.6+10-LTS) in a Raspberry Pi 4B (ARM64) / 4G RAM with CentOS 9 (64-bits).
I have the following add ons:
- Astro
- Netatmo
- System Info
- UniFi
- Hue
- OpenWeatherMap
- Cloud Connector
- Telegram
- UPnP (Iām not sure I had this one in 4.2.0, but itās currently installed in 4.1.3)
- iRobot
- Sonos
- TP-Link Smart Home
- Roku
- Mary Text-to-Speech
Manually installed:
- TapoControl
- Yale/August smart locks
For automation, I only use JRule and 1 or 2 old DSL rules that are not yet fully supported by JRule.
I guess I will have to run a clean installation of 4.2.0, install JRule first, and check. Iāll try to do that this week.
@lsiepel, by this do you mean the /etc/openhab/ folder or /var/lib/openhab/config? I donāt think I have changed anything under /var/ā¦
Hi, @lsiepel.
I upgraded from 4.1.3 to 4.2.1 and JRule loaded successfully. Maybe whatever was messed up with my configuration got fixed after I uninstalled OH and clean-installed 4.1.3.
Thank you for your help!
