JS Scripting: how to define a scene in a .js file (equivalent to a UI scene)?
Hi all,
I’m running openHAB 5.3M1 with the JavaScript Scripting add-on (openhab-js).
When I create a scene in Main UI, the code tab looks like this:
items:
  Rollershutter_GF_Diningroom_WindowCoveringOne: "100"
  Rollershutter_GF_Bedroom_WindowCoveringOne: "100"
triggers: []
conditions: []
I’d like to define the same scene in a file under /etc/openhab/automation/js/ instead. My attempt:
const { items, rules, log } = require('openhab');
rules.JSRule({
  name: 'Szene Schlafen',
  triggers: [],
  tags: ['Scene'],
  execute: (event) => {
    items.Rollershutter_GF_Diningroom_WindowCoveringOne.sendCommand('100');
    items.Rollershutter_GF_Bedroom_WindowCoveringOne.sendCommand('100');
Result:
It looks like this
items:[]
triggers: []
conditions: []
Questions:
  1. What is the correct syntax to create a scene from a JS file so it behaves like a UI scene (ideally with the item/state list visible in the scene editor)?
Thanks!
It’s not possible to do this from JSR223 languages without using a lot of openHAB Core Java APIs directly.
Scenes are just a standard rule with the Scene tag attached and several core.ItemCommandActions specified. JSR223 languages like JS use a single core.ScriptAction for code execution.
You should however be able to define a Scene from a YAML file like this:
version: 1
rules:
  Diner:
    label: Diner at Living Room
    tags:
      - Scene
    description: "Setup lights, increase temperature, turn on AV receiver, set input & volume"
    actions:
      - id: "1"
          command: "30"
          itemName: LivingRoom_CeilingLight
        type: SendCommand
      - id: "2"
          command: "60,0,100"
          itemName: LivingRoom_FloorLamp
        type: SendCommand
      - id: "6"
          command: 21 °C
          itemName: LivingRoom_HVAC_TemperatureSet
        type: SendCommand
      - id: "3"
          command: "ON"
          itemName: LivingRoom_Receiver_Power
        type: SendCommand
      - id: "4"
          command: Server
          itemName: LivingRoom_Receiver_Input
        type: SendCommand
      - id: "5"
          command: 25 %
          itemName: LivingRoom_Receiver_Volume
        type: SendCommand
where do i need to store it?
See YAML Configuration | openHAB.
