This rule should only fire once with a 10 sec block.
Therefore i use a Timer inside the DSL rule, which is working without problems. After 10 sec the rule can fire again.
Is something like that also possible with JSScripting?
my current DSL Rule looks like this:
rule "Klingel Rundruf"
Item Sonoff16_Sensor changed from OFF to ON
if(klingel_sperre === null){
// Klingelsperre für 10s; now.plusMinutes für Minuten
klingel_sperre = createTimer(now.plusSeconds(10), [ |
klingel_sperre = null
val telegramAction = getActions("telegram","telegram:telegramBot:raspi_telegram")
telegramAction.sendTelegramPhoto((Long.decode(Telegram_familie.state.toString)), "http://XXX.XXX.X.XX:XX/snapshot.jpg", "Es klingelt!", "XXXX", "XXXX")
// Fritzbox Rundruf mit XXXXXX
executeCommandLine("/etc/openhab/scripts/klingel.sh")
Yes, of course. See JavaScript Scripting - Automation | openHAB for where to store your Timer variable so you can get it next time the rule runs (note that all your JS Scripting rules will use the same cache so choose names wisely). See JavaScript Scripting - Automation | openHAB for examples of creating timers. Use the following to get to your telegram Thing’s actions.
var telegramAction = actions.thingActions("telegram","telegram:telegramBot:raspi_telegram");
It’s easier to use a timestamp. Just save a timestamp and check to see if it’s been enough time. You’d still use the cache but save a JavaScript joda Date there instead of a Timer. Then instead of testing to see if the timer exists, just test to see if now is enough time past when the timestamp was taken.
It would be best to put that test inside a Condition. If in the UI create a new Condition under “but only if”, choose “Run script” and just add the test there (no if). See JavaScript Scripting - Automation | openHAB for details.
If using text based rules you can put the variable at the top of your file outside of the rules or continue to use the cache. See JavaScript Scripting - Automation | openHAB for details on adding conditions in text based rules.
Thank you very much for your great help.
I am going to switch with JSS over from file based to UI.
Can we already use “let” counter… in the UI without any errors?
How can we use that cache? Sorry for that question but i am completely new to JSS?
A counter is any choosable name of a “cache” variable or does it belong to the cache? What is “times”? Is that the name of the variable? I do not really know what belongs to my saved variable. Can you make it more clear to me?
I need a variable “timestamp”, which should get saved when the rule is fired for the first time. My only if condition would be: now() > timestamp+10sec.
These are the examples of the JSS Page:
Get a previously set value with a default value (times = 0)
