This widget displays a history of state changes stored as a JSON array in a String Item. It is designed as the companion widget for the rule template Logbook: Save Item State as a JSON History [5.2.1;5.9.9.9], but works with any String Item that contains a JSON array in this format:
{"time":"2026-09-27T14:32:10.512+0200","event":"Derating Running"},
{"time":"2026-09-27T09:05:43.120+0200","event":"Running"}
Each entry is shown as a list item:
- Title: relative time (e.g. “5 minutes ago”)
- Subtitle: absolute timestamp (
DD.MM.YYYY HH:mm:ss) - Right side: the recorded state
Features
- Works with any history Item, configured through widget parameters
- Configurable maximum number of displayed entries
- Handles
NULL,UNDEFand invalid content without errors and shows “Keine Einträge vorhanden” (no entries) instead - Item picker only offers String Items
Parameters
| Parameter | Description | Default |
| History Item | String Item containing the JSON history | (required) |
| Title | Title of the card | Logbook |
| Max Entries | Number of entries to display | 10 |
Usage
Set up the rule template for the Item you want to track (or fill a String Item with a JSON array yourself).
Add the widget to a page and select the history Item.
- component: widget:Widget_JSON_History_Logbook config: item: MyDevice_State_History title: Hot Water Status Logbook maxEntries: 10
Changelog
Version 0.1
- initial release
Resources
uid: Widget_JSON_History_Logbook
tags:
* Logbook
* JSON
props:
parameterGroups: [ ]
parameters:
* context: item
description: String Item containing the JSON history (from the rule template)
filterCriteria:
* name: type
value: String
label: History Item
required: true
type: TEXT
* default: Logbook
label: Title
required: false
type: TEXT
* default: "10"
description: Number of entries to display
label: Max Entries
required: false
type: INTEGER
component: oh-list-card
mediaList: true
title: =props.title || 'Logbook'
slots:
default:
* component: oh-repeater
filter: loop.event_idx < (Number(props.maxEntries) || 10)
for: event
in: "=(items\[props.item\].state && items\[props.item\].state.startsWith('\[')) ? JSON.parse(items\[props.item\].state) : [ ]"
sourceType: array
slots:
default:
- component: oh-list-item
after: =loop.event.event
subtitle: =dayjs(loop.event.time).format('DD.MM.YYYY HH:mm:ss')
title: =dayjs(loop.event.time).fromNow()
* component: oh-list-item
title: No entries
visible: "=!(items\[props.item\].state && items\[props.item\].state.startsWith('\[') && items\[props.item\].state.length > 2)"
