Json parsing in the things file using paper UI doesnt want to work
I am trying to figure out a JSON parsing issue nightmare. If some one could give a little push I would really appreciate it:
Here is some info about my setup:
  • Hardware: Raspberry pi3
  • OS: Rasbian OS
  • openHAB version:openHAB 2.5.10 Release Build
  • working map -> miflora-mqtt-daemon -> mosquitto mqqt -> openHab2
things file: (other code parts ommited)
Type string : version [stateTopic=“miflora/JapaneseBonsai”, transformationPattern=“JSONPATH:$.light” ]
on the miflora/JapaneseBonsai topic mosquito client shows this info:
Client mosqsub/1981-raspberryp received PUBLISH (d0, q0, r0, m0, ‘miflora/JapaneseBonsai’, … (85 bytes))
{“light”: 0, “temperature”: 10.2, “moisture”: 33, “conductivity”: 992, “battery”: 27}
adding the thing to my PaperUI control panel I get this:
openHabTwo|348x277
I looked at the examples of JSONPATH and it looks like this is supposed to work. I tried to approach this in many ways, but could not succeed.
My main goal is to take the light value which is 0 now and get is as a number.
Do you have the json path transformation installs
http://openhabianpi:8080/paperui/index.html#/extensions?tab=transformation
No,
I installed the basic version.
Marked as solution :slight_smile:
