Sorry for the long post in advance.
Everything is working properly, I am having some trouble getting rid of these warning from my log. I am not sure if I need to use a rule or how to create a JS or use the proper Transform.
I am contolling a Tasmota ESP8266 WiFi Light (Dimmer) and Fan Controller.
These are the warnings…
[t.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.Dimmer' in '{"POWER1":"ON"}'
[t.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.POWER2' in '{"POWER1":"ON"}'
[t.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.Dimmer' in '{"POWER2":"ON"}'
This is my MQTT thing.
Thing topic EndBedroomLightsFan "End Bedroom Lights Fan" {
Channels:
Type switch : fanpower "Fan Power Switch" [ stateTopic= "EndBedroomLightsFan/stat/POWER1", commandTopic="EndBedroomLightsFan/cmnd/POWER1", on="ON", off="OFF"]
Type string : fanspeed "Fan Speed" [ stateTopic= "EndBedroomLightsFan/stat/speed", commandTopic="EndBedroomLightsFan/cmnd/tuyasend4", turtle="3,0", low="3,1", medium="3,2", high="3,3"]
Type switch : lightspower "Lights Power Switch" [ stateTopic= "EndBedroomLightsFan/stat/RESULT", transformationPattern="JSONPATH:$.POWER2", commandTopic="EndBedroomLightsFan/cmnd/POWER2", ON="ON", OFF="OFF"]
Type dimmer : lightspercent "Lights Percent" [ stateTopic= "EndBedroomLightsFan/stat/RESULT", transformationPattern="JSONPATH:$.Dimmer", commandTopic="EndBedroomLightsFan/cmnd/Dimmer"]
Whenever the MQTT comes in, the RESULT topic is not consistent and always changes according to whatever is controlled on the Light/Fan switch.
- When Fan Power Switch is turned on/off it send the MQTT message {“POWER1”:“OFF”}
- When Light Power Switch is turned on/off it send the MQTT message {“POWER2”:“OFF”}
- Whenever Dimmer is adjusted it send the MQTT message {“POWER2”:“ON”,“Dimmer”:72}
This is what creates the error according to my transformationPattern you can see there is not a valid path when looking at my Thing.
Any idea how do I go about trying to get rid of these warnings and properly handle this Thing? I am not a very strong Javascript/ JSON person so I am sure this could be easy if you know what you are doing
Thanks!
