psyciknz
(Psyciknz)
August 20, 2020, 1:31am
1
I know I’ve got an escaping issue.
I have thw following json I want to me able to send as the on Commandtopic for mqttv2:
on="{"command":"c:\\Windows\\SysWOW64\\WindowsPowerShell\\v1.0\\powershell.exe"},
I’ve left the json as I want it to appear in teh mqtt server.
What escaping do I need to get it to supply the above.
I’ve tried replacing all the internal " with ’ and “” and " to no avail.
Can you show the full configuration? The snippet is certainly missing at least a trailing "…
My first guess would be:
on="{\"command\":\"c:\\Windows\\SysWOW64\\WindowsPowerShell\\v1.0\\powershell.exe\"}",
… though you may need to adjust all your double \\
to quadruple \\\\
psyciknz
(Psyciknz)
August 20, 2020, 5:28am
3
Thing mqtt:topic:iotlinkaragorn "IOTLink Aragorn" (mqtt:broker:mosquitto) @ "Cupboard"
Channels:
Type switch : namovm "Namo-VM" [ stateTopic="iotlink/workgroup/aragorn/lwt",
on="{ command: c:\\Windows\\SysWOW64\\WindowsPowerShell\\v1.0\\powershell.ex, args: -Command resume-vm sago-ld, path: c:\\, user: , visible: false, fallback: true }",
off="{ command: c:\\Windows\\SysWOW64\\WindowsPowerShell\\v1.0\\powershell.ex, args: -Command suspend-vm sago-ld, path: c:\\, user: , visible: false, fallback: true }",
commandTopic="iotlink/workgroup/aragorn/commands/run"
Type contact : online "online" [ stateTopic="iotlink/workgroup/aragorn/lwt",on="ON", off="OFF"]
It’s for running a powershell command via IOTLink on windows.
system
(system)
Closed
September 30, 2020, 9:29pm
4
