opus
(Jürgen Baginski)
March 28, 2018, 7:16pm
1
I’m trying to use JSONPATH and REGEX transformation on the return of a web-request, however I’m hitting a wall:
The item:
String Tasmota2_Release "Tasmota2 Release: [%s]" { http="<[tasmota:10000:JSONPATH($[0].name)]"}
gets the state “v5.12.0”
Now, I want to have it without the “v”. I figured a REGEX of “\d{1,2}.\d{1,2}.\d{1,2}” would do the trick (checked with https://regex101.com/ ).
The item changed to:
String Tasmota2_Release "Tasmota2 Release: [%s]" { http="<[tasmota:10000:JSONPATH($[0].name):\d{1,2}.\d{1,2}.\d{1,2})]"}
produces initially the syntax warnings:
20:52:28.230 [WARN ] [del.core.internal.ModelRepositoryImpl] - Configuration model 'Haus.items' has errors, therefore ignoring it: [57,58]: mismatched character 'd' expecting set null
[57,97]: mismatched input '{' expecting RULE_STRING
[57,98]: missing '}' at '1'
[57,99]: extraneous input ',' expecting RULE_ID
[185,117]: mismatched character '<EOF>' expecting '"'
and when the item is requested by an UI following erors:
21:06:54.367 [WARN ] [.basic.internal.render.SwitchRenderer] - Cannot determine item type of 'Light_Dual2'
for nearly all items, but not the one in question.
Is the usage of JSONPATH and REGEX for an item possible at all?
Josar
(Josar)
March 28, 2018, 8:34pm
2
The errors come from not escaping backslash in a string, see doc . And from a stray )
at the end.
I didn’t test it but the doc says, you can use cascaded transformation with the http binding.
String Tasmota2_Release "Tasmota2 Release: [%s]" { http="<[tasmota:10000:JSONPATH($[0].name):\\d{1,2}.\\d{1,2}.\\d{1,2}]"}
If not i would suggest to use the regex at the label.
String Tasmota2_Release "Tasmota2 Release: [REGEX(\\d{1,2}.\\d{1,2}.\\d{1,2}):%s]" { http="<[tasmota:10000:JSONPATH($[0].name)]"}
opus
(Jürgen Baginski)
March 29, 2018, 3:33am
3
Sometimes one doesn’t see the wood because of all those trees!
Thanks.
opus
(Jürgen Baginski)
March 29, 2018, 7:20pm
4
Did some tries to incooperate it. It didn’t work using the label, nor did it work cascading (i.e. JSONPATH and REGEX in the item definition).
I finally just used a JavaScript to do the job.
(function(i) {
var version =JSON.parse(i)[0].name;
return version.substring(1);
})(input)
Josar
(Josar)
April 2, 2018, 11:50pm
5
So jsonpath and regex does not work?
Did you check if both transformatino Services are installed?
opus
(Jürgen Baginski)
April 3, 2018, 5:30am
6
Both were and are installed, I didn’t get it them to work.
