So much simpler than I expected, for anyone else who is interested!
rule "Get Power Usage"
//Item TestSwitch changed to ON
Time cron "0 * * * * ?"
var String json = sendHttpGetRequest("http://NeurioIP/current-sample")
var String value = transform("JSONPATH", "$.channels[2].p_W", json)
logInfo("NEURIO","************* Current Usage: " + value )
postUpdate(power_Neurio, value)
Number power_Neurio "Current Power Usage [%.1f W]"
I’m having a problem using JSONPath to retrieve value of a JSON node which contains blanks in the node name. This is the part of the JSON result I’m struggling to parse:
\"Indeks kvaliteta zraka\":\"386\"
As you can see, it contains an empty spaces in the name, so, when I try to parse it using JSONPath, it returns the whole JSON result, not just a result of the node I want. I’ve tried surrounding it with square brackets and single quotation marks, but without success. Is there a way to parse it using JSONPath?
For the record: https://github.com/json-path/JsonPath#what-is-returned-when
This seems to match what I see in my setup. I get scalars for simple queries but as soon as I include .. or ?(<expr>) an array is returned even if there is one item.
