- Platform information:
- Hardware: Raspberry Pi Model 3B+
- OS: Linux devpi 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
- Java Runtime Environment: OpenJDK Runtime Environment Zulu11.54+25-CA (build 11.0.14.1+1-LTS)
- openHAB version: 3.2.0 - Release Build
BACKGROUND: I am writing a rule to turn on/off a collection of switches based on the power being generated by my solar panels - the basic objective is to use all the power being generated and not export any to the grid. The sorts of devices being turned on/off are pool pumps, hot tub heaters, underfloor fans etc.
The user gets to configure up to 10 switches with details such as:
- Watts drawn by the device plugged into the switch
- Switch priority (high, medium, low) - used by my rule to determine what to turn on first
- Minimum minutes it should stay on once turned on (to prevent flapping)
- Minimum minutes it should stay off once turned off (to prevent flapping)
- Maximum minutes it should be on in one day
Once the configuration is complete, the data needs to be stored in a “database” that I can query easily. I have chosen a JSONPATH string to store this data (let me know if you think there is a better way). I have validated my JSONPATH string OK. It looks like this:
"Consumers": [{
"ID": 0,
"DisplayName": "Pool Pump",
"ItemName": "Poolpumps_switch1",
"Priority": 0,
"WattsDrawn": 1000,
"MaxDailyMins": 0,
"MinONMins": 10.0,
"MinOFFMins": 10.0
"ID": 1,
"DisplayName": "Hot Tub",
"ItemName": "Hottub_switch1",
"Priority": 1,
"WattsDrawn": 210,
"MaxDailyMins": 0,
"MinONMins": 10.0,
"MinOFFMins": 10.0
"ID": 2,
"DisplayName": "Underfloor Fans",
"ItemName": "Underfloorfans_switch1",
"Priority": 2,
"WattsDrawn": 50,
"MaxDailyMins": 0.0,
"MinONMins": 10.0,
"MinOFFMins": 10.0
"ID": 3,
"DisplayName": "unused",
"ItemName": "unused",
"Priority": null,
"WattsDrawn": null,
"MaxDailyMins": null,
"MinONMins": null,
"MinOFFMins": null
"ID": 4,
"Priority": null,
"WattsDrawn": null,
"MinONMins": null,
"MinOFFMins": null
"ID": 5,
"Priority": null,
"WattsDrawn": null,
"MinONMins": null,
"MinOFFMins": null
"ID": 6,
"Priority": null,
"WattsDrawn": null,
"MinONMins": null,
"MinOFFMins": null
"ID": 7,
"Priority": null,
"WattsDrawn": null,
"MinONMins": null,
"MinOFFMins": null
"ID": 8,
"Priority": null,
"WattsDrawn": null,
"MinONMins": null,
"MinOFFMins": null
"ID": 9,
"Priority": null,
"WattsDrawn": null,
"MinONMins": null,
"MinOFFMins": null
ISSUE: I have used jsonquerytool.com to construct a query to get a list of IDs that do not have a DisplayName of “unused”. The query is $..[?(@.DisplayName!="unused")].ID
and in the query tool it returns [ 0, 1, 2 ]
as expected.
In the openHAB rule, I have the following:
str = transform("JSONPATH", '$..[?(@.DisplayName!="unused")].ID', MPConsumersString.state.toString)
str2 = transform("JSONPATH", '$..[?(@.DisplayName=="unused")].ID', MPConsumersString.state.toString)
logInfo("MP", "str=" + str)
logInfo("MP", "str2=" + str2)
The output I see in the log is:
str=[0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, 1, 2]
str2=[3, 4, 5, 6, 7, 8, 9]
str2 is as expected (IDs 3-9 have a DisplayName of “unused”)
str is unexpected. I expected just str=[0, 1, 2]
I don’t know why I am getting ID’s 0-9 and 0-2.
Can someone see what I am doing wrong?
Thanks in advance.
