Platform information:
Hardware: Rpi4B
OS: Openhabian (Linux openhabian4B 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux)
Java Runtime Environment:
openjdk version "1.8.0_222"
OpenJDK Runtime Environment (Zulu8.40.0.178-CA-linux_aarch32hf) (build 1.8.0_222-b178)
OpenJDK Client VM (Zulu8.40.0.178-CA-linux_aarch32hf) (build 25.222-b178, mixed mode, Evaluation)
openHAB version: 2.5.6 (Build)
Issue of the topic:
I don’t know why I can’t get the value
Original MQTT Msg:
zigbee/send {"cmd":"report","id":2000000755,"did":"lumi.158d00012653fb","time":1629707070473,"rssi":-49,"zseq":54,"params":[{"res_name":"3.1.85","value":1}],"dev_src":"0"}
Things:
Type string : PIR3 "Motion Sensor" [ stateTopic="zigbee/send", transformationPattern="REGEX:(.*158d00012653fb.*)∩JSONPATH:$.params.res_name" ]
And I got error from Console
16:24:30.878 [WARN ] [tt.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.params.res_name' in '{"cmd":"report","id":2000000755,"did":"lumi.158d00012653fb","time":1629707070473,"rssi":-49,"zseq":54,"params":[{"res_name":"3.1.85","value":1}],"dev_src":"0"}'
I get no error if I only use $.params or $.rssi
does error come from _?
what can I do?
