Hello everyone, I need your help:
I need to read this string JSONPATH {“NSPanel”:{“ctype”:“group”,“id”:“2”,“params”:{“switches”:[{“switch”:“off”,“outlet”: 0},{“switch”:“off”,“outlet”:1}]}}}
the values to read are id,switch and outlet commands of my nspannel widgets which must have the values 2,off,0 for off status and 2,on,0 for on status but I can’t set them.
so I ask for your help
ubeaut
(Greg)
January 24, 2023, 9:54am
#2
ECMAScript 262 Edition 5.1 json.parse.
var test = JSON.parse('{"NSPanel":{"ctype":"group","id":"2","params":{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}]}}}');
logger.info("id: " + test.NSPanel.id)
logger.info("switch: " + test.NSPanel.params.switches[0].switch)
logger.info("outlet: " + test.NSPanel.params.switches[0].outlet)
logger.info("switch: " + test.NSPanel.params.switches[1].switch)
logger.info("outlet: " + test.NSPanel.params.switches[1].outlet)
Which gives output of:
[2023-01-24 20:51:27.297 [INFO ] [org.openhab.rule.50ccdb9783 ] - id: 2
2023-01-24 20:51:27.298 [INFO ] [org.openhab.rule.50ccdb9783 ] - switch: off
2023-01-24 20:51:27.298 [INFO ] [org.openhab.rule.50ccdb9783 ] - outlet: 0
2023-01-24 20:51:27.299 [INFO ] [org.openhab.rule.50ccdb9783 ] - switch: off
2023-01-24 20:51:27.300 [INFO ] [org.openhab.rule.50ccdb9783 ] - outlet: 1
can you send a tutorial on how to set it up? thank you
