i’m running in basic problem with jsr223 javascript. How is it possible to catch events in a single rule in this pattern:
var startT = -1;
var runT = 0;
var x = 0;
var delayT = function() {
if (runT == 0) {
runT = 1;
while ((startT + 4000) > (new Date().getTime())) {x = 0;} // runs 4000ms
runT = 0;
logInfo("FINISHED !!!!")
} else {
logInfo("is running ...")
var testR = JSRule({
description: "only for testing",
triggers: [ItemCommandTrigger("TestSwitch")],
execute: function( module, input){
logInfo("START *****");
startT = new Date().getTime();
delayT();
logInfo("END *******")
Currently i see the follwowing behavior:
When the TestSwitch is pressed the rule testR is called, in the log i can see START and 4s later i see FINISHED and END. But when the TestSwitch, within the 4s, is pressed again the event is “perssisted” and after the logInfo - END the rule runs the second time.
I would expect when the TestSwitch is changed within the 4s the rule is triggerd in a second, third, … instance. Then the rule called the function delayT() and this should run in the else branch and write "is running …, because the variable runT is set to 1 in the first instance.
I’m running OH 2.4.0.
Thanks, Torsten
