Thank you for replying, rossko57!
I was going to dismiss the theory outright because I first saw the problem on a “received update” rule on an item that was updated by postUpdate in a rule triggered by astro, not the GUI.
But, I figured you might be right, so I decided to test it thoroughly, and the test results shows that it is not in the gui.
Here’s the test setup:
Items:
Switch RaceGuiSwitch "Race Condition Gui Item" <lightbulb> (Bench)
Switch RaceItemSwitch "Race Condition Item"
racecondition.py
from core.rules import rule
from core.triggers import when
from core.log import logging, LOG_PREFIX
log = logging.getLogger(LOG_PREFIX + ".racetest")
def logprint(text):
log.debug(text)
@rule("RaceGuiSwitch", description="", tags=["utility"])
@when("Item RaceGuiSwitch changed from OFF to ON")
def RaceGuiSwitch(event):
events.postUpdate(ir.getItem("RaceItemSwitch"),ON)
@when("Item RaceGuiSwitch changed from ON to OFF")
events.postUpdate(ir.getItem("RaceItemSwitch"),OFF)
@rule("RaceItemSwitch", description="", tags=["utility"])
@when("Item RaceItemSwitch received update")
def RaceItemSwitch(event):
logprint("ir.getItem().getState(): " + str(ir.getItem("RaceItemSwitch").getState()) + " event.itemState:" + str(event.itemState))
Here’s the console output:
2019-06-14 20:06:13.706 [DEBUG] [jsr223.jython.racetest ] - ir.getItem().getState(): OFF event.itemState:OFF
2019-06-14 20:06:14.990 [DEBUG] [jsr223.jython.racetest ] - ir.getItem().getState(): OFF event.itemState:ON
2019-06-14 20:06:15.685 [DEBUG] [jsr223.jython.racetest ] - ir.getItem().getState(): OFF event.itemState:OFF
2019-06-14 20:06:16.500 [DEBUG] [jsr223.jython.racetest ] - ir.getItem().getState(): ON event.itemState:ON
2019-06-14 20:06:16.992 [DEBUG] [jsr223.jython.racetest ] - ir.getItem().getState(): OFF event.itemState:OFF
2019-06-14 20:06:17.446 [DEBUG] [jsr223.jython.racetest ] - ir.getItem().getState(): OFF event.itemState:ON
2019-06-14 20:06:17.743 [DEBUG] [jsr223.jython.racetest ] - ir.getItem().getState(): OFF event.itemState:OFF
The discrepancy between getItem().getState() and event.itemState could not have come from the GUI because the RaceItemSwitch is decoupled from RaceGuiSwitch by two rules: “changed from ON to OFF” and “changed from OFF to ON”.
I also implemented the test rule in Rules DSL, as follows:
rule "test race condition"
logInfo("rules DSL","item state: " + RaceItemSwitch.state)
pi@openhab:~ $ tail -f /var/log/openhab2/openhab.log | grep jython
2019-06-14 20:18:50.457 [DEBUG] [jsr223.jython.racetest ] - ir.getItem().getState(): ON event.itemState:ON
2019-06-14 20:18:50.658 [DEBUG] [jsr223.jython.racetest ] - ir.getItem().getState(): OFF event.itemState:OFF
2019-06-14 20:18:50.891 [DEBUG] [jsr223.jython.racetest ] - ir.getItem().getState(): OFF event.itemState:ON
2019-06-14 20:18:51.071 [DEBUG] [jsr223.jython.racetest ] - ir.getItem().getState(): OFF event.itemState:OFF
2019-06-14 20:18:51.263 [DEBUG] [jsr223.jython.racetest ] - ir.getItem().getState(): ON event.itemState:ON
^C
pi@openhab:~ $ tail -f /var/log/openhab2/openhab.log | grep DSL
2019-06-14 20:18:50.471 [INFO ] [pse.smarthome.model.script.rules DSL] - item state: ON
2019-06-14 20:18:50.670 [INFO ] [pse.smarthome.model.script.rules DSL] - item state: OFF
2019-06-14 20:18:50.916 [INFO ] [pse.smarthome.model.script.rules DSL] - item state: ON
2019-06-14 20:18:51.085 [INFO ] [pse.smarthome.model.script.rules DSL] - item state: OFF
2019-06-14 20:18:51.273 [INFO ] [pse.smarthome.model.script.rules DSL] - item state: ON
^C
Note how it does NOT show any problem! I spammed the GUI button for several minutes, could not trip it up. So this problem looks to be inherent to JSR223, or perhaps the next gen rule engine, or perhaps Jython. That makes more sense – a bug of this magnitude couldn’t remain if it affected the majority of users and uses.
Now, the reason I’m not using Rules DSL is that as I read through the documentation, I came across some (to my eyes as a programmer) ugly workarounds around the lack of being able to define functions, and then in this document i came across this:
Upon reading this, and seeing as I was dumping my $600+ Fibaro Home Center 2 and switching to Openhab mostly because of annoying scripting limitations that make anything beyond the simplest of systems a maintenance nightmare, I realized that Rules DSL would indeed NOT be for me, and that perhaps it was time to learn a new language. And that is how after 20 years of C++ experience, I started learning Python! ![]()
So anyway. Could anyone else help confirm this race condition in JSR223/Python rule handling?
