The ChangedEventTrigger can optionally specify a “from state” and “to state”. You’d use this if you only want to trigger on a change from OFF to ON, for example, but not from ON to OFF. The UpdatedEventTrigger is fired on every state update (even if the update is the same as the current value) so the “from” and “to” states are not relevant.
