JSScript compare event.itemState with Number
OHM3
How do I compare an event.itemState that is a Number in a JavaScript GUI based script? I can convert to a string, but that seems suboptimal:
if (event.itemState.toString == "2") {
The itemState should be an object, with getItemState function you can get the state object. State will have a compare function…
Which JS are you using? If it’s GraalVM JS Scripting ECMAScript 11, it depends whether the Item’s state has units or not.
// without units
if(event.itemState.intValue() == 2)
// with units
var state = Quantity(event.itemState);
var constant = Quantity("2 W"); // where you replace "W" with what ever units are being used
if(state.equals(constant))
