Hello everyone,
I’m facing a very strange issue on my openHAB installation (Version 4.3.5) and I’m out of ideas.
My Goal:
I’m trying to create a simple rule to calculate daily energy consumption from a power Item (in Watts).
The Problem:
Any attempt to use JSScripting fails because the standard openHAB global objects are not being loaded into the script’s scope. When a rule runs, I get errors like ReferenceError: "itemRegistry" is not defined
or TypeError: undefined has no such function "averageSince"
when trying to use actions.Persistence
It seems my JS Scripting engine is running in an isolated state, without the necessary openHAB integrations.
Troubleshooting I’ve Already Done:
I have already tried the following steps multiple times, without any success:
- Verified that my persistence service (RRD4J) is working correctly. I can see the data in charts and query it via the API Explorer.
- Attempted multiple JSScripting variations to access persistence (
item.history
,actions.Persistence
, and even direct Java calls viaPersistenceExtensions
). All of them fail because the required global objects are undefined. - Completely uninstalled and re-installed the JS Scripting automation addon.
- Restarted openHAB multiple times.
- Cleared the cache using the
openhab-cli clean-cache
command.
Here is the last version of the code I tried, which fails with ReferenceError: "itemRegistry" is not defined
var ZonedDateTime = Java.type(“java.time.ZonedDateTime”);
var PersistenceExtensions = Java.type(“org.openhab.core.persistence.extensions.PersistenceExtensions”);
var powerItemName = “Tesla_Powerwall_Instant_Home_Power”;
var powerItem = itemRegistry.getItem(powerItemName); // This line fails
if (powerItem) {
var startOfDay = ZonedDateTime.now().withTimeAtStartOfDay();
var avgPower = PersistenceExtensions.averageSince(powerItem, startOfDay, “rrd4j”);
// … rest of the logic
Has anyone seen this behavior before or has any idea what else could be causing this? Any help would be greatly appreciated.
Thank you!
