Preface this by saying… I’m completely new to OpenHAB and Raspberry Pi. Below is what I have done so far, Is there anything else I need to do setup-wise before I start to learn and figure out how to add devices and create some automations? Thanks so much!
Initial install was done by writing the OpenHABian 2.2.0-1 to the MicroSD card and powering up the Raspberry Pi.
OpenHAB and Raspberry Pi booted and obtained an IP address.
I’m able to connect to the Dashboard via IPaddress:8080
Thanks @Moxified! How about a Site Map or any other components that I should install? Is that required before I begin? Also, will using the “Experimental” Rules add-on work for basic automations? Appreciate it!
Please note that the experimental rule engine is still called experimental…meaning you may get weird errors and malfunctions despite you doing everything correctly; not too many users of it either in the forum it appears, so you may have a harder time getting questions answered…just some thoughts
Thanks @lipp_markus. I’ll check out the link you sent. If the Rule add-on isn’t used/supported by many here that’s too bad. Writing code to do automations is something I’ll need to learn since I have zero experience. Appreciate it.
Thanks @Moxified. I installed the NTP binding but it doesn’t appear it adjusted the time… if I did it correctly. The other link you sent is over my head at this point. Need to read and learn more!
