I’ve updated from OH 3.1.0 to 3.2.0 (docker image openhab/openhab:3.2.0) a couple of days ago. Everything is looking good so far and nearly everything seems to work - but one Thing.
I have a Z-Wave thermostat which does not work show the details in the basic web view (settings/things). It just shows green “Status: online” but it does not work.
I’ve already deleted the cache and temp folders, does a couple or restarts and also try to actively REQUEST_NIF with the thermostat Z-Wave menu. As far as I understand, the logging in OH looks good so far:
Thing ‘zwave:honeywell_th6320zw_00_000:myzwave:tkitc_thermostat’ changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
All (about 50) other Z-Wave devices are working. The thermostat shows Z-Wave communication is ok on it’s display. I can’t find error messages in the OH logfiles.
When I try to change the temperature setpoint in habpanel from current 75 to 76, I will get the following messages in the logfile and it will fall back to 75:
2022-02-09 08:18:50.077 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘aKITC_Thermostat_Setpoint_Heating_Temp’ received command 76
2022-02-09 08:18:50.078 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘aKITC_Thermostat_Setpoint_Heating_Temp’ predicted to become 75.0
Do you think that because of the update from OH 3.1 to 3.2 the channel type has changed? Because it’s the same Z-Wave thermostat which I’m using since 2 years.
I’m not sure if I should include it again from scratch (and exclude before), or will it be ok to just change the type in the items file? I’ve configured everything with files - I only use the basic web GUI for checking/monitoring states of the things.
I’ve done a new Z-Wave device discovery scanning. In the in-box I’ve found the same node ID (26) but with the hint “Unknown Device: Z-Wave Node 026 (0039:0011:0008:1.3)” not in database?!
Is it possible that the new OH 3.2 Z-Wave device database has removed a device which was known in the previous version OH 3.1?
Ok, I solved it. I’ve stopped the 3.2.0 bundle via CLI and installed and started the 3.3.0-SNAPSHOT bundle via CLI. After a restart of the OH docker container the the new bundle is active and the problems are gone
Btw. I’ve also changed the units to number:temperature
