language: JYTHON rule
trying out sendHttpGetRequest. the result is json.
Guess I have to use "transform and JSONPATH to get the individual values in json string.
what do I need to import?
Assuming you are using the helper libraries, all the core Actions are documented here.
from core.actions import Transformation
Transformation.transform("JSONPATH", "$.test", test)
One way is to import json. This works for me. Note the “json.loads(response)” to get it into a dictionary. See https://www.w3schools.com/python/python_json.asp
from core.rules import rule
from core.triggers import when
from core.actions import HTTP
import json
@rule("Filtrete Thermostat Update", description="Picks up Filtrete thermostat status", tags=[])
@when("Time cron 37 * * * * ?")
def thermostatCollectData(event):
response = HTTP.sendHttpGetRequest("http://192.168.1.210/tstat", 10000)
# thermostatCollectData.log.info(response)
jsonResponse = json.loads(response)
events.postUpdate("Tstat_state", str(jsonResponse["tstate"]))
thanks! tried to search (google, search function on the site), didn’t find it.
I’ll try this and the other answer…
thx!
great, I’ll try this answer too
thx!
In openHAB 3.4 this is not working anymore:
ImportError: cannot import name Transformation in /etc/openhab/automation/jsr223/python/personal/speedtest.py at line number 6
