I am trying to use the function add_item from items.py (core) but I always get an error:
2019-01-21 19:34:00.847 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab2/automation/jsr223/personal/003_initialize.py': ImportError: cannot import name JythonItemProvider in <script> at line number 6
And line 6 is:
from core.items import add_item
Seems that I have an issue with importing JythonItemProvider (which is created in 200_JythonItemProvider).
I am also just starting with Jython. Maybe your “003_initialize.py” calls it too early?
As far as I understand, the number before the script name makes in which order it is executed. Does it work if you modify a script in order it is reloaded?
I just added the following to my script:
from core item import add_item
… add_item("addeditem","Switch")
After that my items are gone away:
File “/openhab/conf/automation/lib/python/core/log.py”, line 43, in wrapper
return fn(*args, **kwargs)
File “”, line 210, in checksetSetpoint
AttributeError: ‘org.eclipse.smarthome.automation.module.script.def’ object has no attribute ‘storm’
At that line I accessed “items.storm” whereby storm was a Switch item
