First of all, I would like to thank everybody involved to openHAB and especially those who made jsr223-scripting possible.
While there are good points for openHAB DSL, my opinion is, that there are some tasks where
jsr223-scripting seems to be more appropriate.
I discovered this topic not long ago, so I consider myself a NewBie.
Here is my challenge:
The code in /lib/init.py (underscores not shown) attempts to add an attribute-resolver to the items map.
This is used in /scripts/examples/testing_example.py, but on my system it causes an ERROR being logged as below:
13:02:14.726 [ERROR] [e.smarthome.automation.rules.callback] - Traceback (most recent call last):
File "/etc/openhab2/lib/python/openhab/triggers.py", line 119, in execute
self.callback(module, inputs) if self.extended else self.callback()
File "/etc/openhab2/lib/python/openhab/triggers.py", line 147, in callback
result_value = fn(*fn_args)
File "<script>", line 19, in double_the_value
AttributeError: 'org.eclipse.smarthome.automation.module.script.def' object has no attribute 'TestNumber1'
13:02:14.728 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - bb02c8b3-7995-434f-9859-e8c68f88294b updated: IDLE
13:02:15.708 [ERROR] [ROOT ] - {
"run": 1,
"errors": [{"name":"__builtin__.MyUnitTest.test_item", "stack":"Traceback (most recent call last):
File \"<script>\", line 33, in test_item
AttributeError: 'org.eclipse.smarthome.automation.module.script.def' object has no attribute 'TestNumber2'
"failures": [],
"skipped": []
an additional import import openhab
did not help.
after changing the 2 lines:
18 events.postUpdate("TestNumber2", str(2 * items.TestNumber1.floatValue()))
18 events.postUpdate("TestNumber2", str(2 * items["TestNumber1"].floatValue()))
32 self.assertEqual(items.TestNumber2.floatValue(), 10)
32 self.assertEqual(items["TestNumber2"].floatValue(), 10)
it runs ok, Log below:
13:09:32.317 [INFO ] [port.shared.ScriptedAutomationManager] - removeAll added handlers
13:09:32.335 [INFO ] [ort.internal.loader.ScriptFileWatcher] - Loading script 'examples/testing_example.py'
13:09:32.339 [INFO ] [smarthome.event.RuleRemovedEvent ] - Rule 'bb02c8b3-7995-434f-9859-e8c68f88294b' has been removed.
13:09:32.381 [INFO ] [smarthome.event.RuleAddedEvent ] - Rule '919a7ea7-e531-44de-b0f0-f8982dd83d38' has been added.
13:09:32.385 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 919a7ea7-e531-44de-b0f0-f8982dd83d38 updated: INITIALIZING
13:09:32.389 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 919a7ea7-e531-44de-b0f0-f8982dd83d38 updated: IDLE
13:09:32.422 [INFO ] [smarthome.event.ItemStateChangedEvent] - TestNumber1 changed from NULL to 5
13:09:32.424 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 919a7ea7-e531-44de-b0f0-f8982dd83d38 updated: RUNNING
13:09:32.438 [INFO ] [smarthome.event.ItemStateChangedEvent] - TestNumber2 changed from NULL to 10.0
13:09:32.442 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 919a7ea7-e531-44de-b0f0-f8982dd83d38 updated: IDLE
13:09:33.417 [INFO ] [port.shared.ScriptedAutomationManager] - removeAll added handlers
13:09:33.434 [INFO ] [smarthome.event.RuleRemovedEvent ] - Rule '919a7ea7-e531-44de-b0f0-f8982dd83d38' has been removed.
13:09:33.436 [INFO ] [ort.internal.loader.ScriptFileWatcher] - Loading script 'examples/testing_example.py'
13:09:33.472 [INFO ] [smarthome.event.RuleAddedEvent ] - Rule 'ecdbf764-296e-4494-b21c-9f5d465586da' has been added.
13:09:33.476 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - ecdbf764-296e-4494-b21c-9f5d465586da updated: INITIALIZING
13:09:33.487 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - ecdbf764-296e-4494-b21c-9f5d465586da updated: IDLE
13:09:33.514 [INFO ] [smarthome.event.ItemStateChangedEvent] - TestNumber1 changed from NULL to 5
13:09:33.528 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - ecdbf764-296e-4494-b21c-9f5d465586da updated: RUNNING
13:09:33.532 [INFO ] [smarthome.event.ItemStateChangedEvent] - TestNumber2 changed from NULL to 10.0
13:09:33.534 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - ecdbf764-296e-4494-b21c-9f5d465586da updated: IDLE
Since I am not professional with python, I cannot sort out, if this is a possible configuration problem, or
a problem with the (discontinued) init.py.
The above Log shows, that the file is being logged to be loaded twice. This is addressed in another post.
Any hint is appreciated.
