I’m running the latest openHAB 2.5.5 release and see that there’s a problem in one of my rules where I convert a state to String
. I understood that when using str()
I would be using a plain Python string
in that case, but this seems to be an incorrect assumption as instead I get a org.eclipse.smarthome.core.library.types.StringType
Code snippet:
@rule(
rulePrefix + "Sun Time of Day changed",
description=u"Sun Time of Day changed" + ruleTimeStamp,
tags=["TimeOfDay", "Astro", ruleTimeStamp],
@when("System started")
@when("Item {} changed".format(my_rule_items.SUN_TIME_OF_DAY))
def Rule_SunTimeOfDayChanged(event):
global logTitle
logPrefix = "Rule_SunTimeOfDayChanged(): "
if event:
oldState = (
"(Not defined)"
if event.oldItemState is None
else str(event.oldItemState) # seems to return org.eclipse.smarthome.core.library.types.StringType (not java.lang.String)
newState = event.itemState
else:
item = ir.getItem(my_rule_items.SUN_TIME_OF_DAY)
if item:
oldState = "(unknown)"
newState = str(item.state) # seems to return org.eclipse.smarthome.core.library.types.StringType (not java.lang.String)
else:
oldState = "(Item not in item registry)"
newState = oldState
Telegram.sendTelegram(
defaults.TELEGRAM_BOT_NAME,
"<b>Sun: Time Of Day</b> {item} changed from <pre>{oldState}</pre> to <pre>{newState}</pre>: <b>{tod}</b>).".format(
item=my_rule_items.SUN_TIME_OF_DAY,
oldState=oldState,
newState=newState,
tod=capitalizeWords(" ".join(newState.split("_"))), # ERROR OCCURS HERE AT `split()`
Error log:
2020-05-26 13:42:12.955 [ERROR] [ime Of Day | Sun Time of Day changed] - Traceback (most recent call last):
File "/etc/openhab2/automation/lib/python/core/log.py", line 52, in wrapper
return fn(*args, **kwargs)
File "<script>", line 150, in Rule_SunTimeOfDayChanged
AttributeError: 'org.eclipse.smarthome.core.library.types.StringTyp' object has no attribute 'split'
Is this intentional? How can I fix this so that split()
works (again) as expected?
