How can I test whether a member of the item registry is a group item or not?
So far I only found out type(member) but then I need to parse the 2 space-separated values and have access to the OH types from within Jython (unless I hard-code them in my rule).
For instance,
g = itemRegistry.getItem("gTripleToggle")
# Rules DSL: if not g instanceof GroupItem:
if str(type(g)) != "<type 'org.eclipse.smarthome.core.items.GroupItem'>":
# Error case - stop
else:
# Expected situation - proceed
The conditional could also be hacked as follows:
if str(type(g)).split("'")[1].split(".")[-1] == "GroupItem":
This is not a direct answer to your question, but I think you may find the information you’re after in the following code I wrote some time ago to explore groups and group members using Jython:
from org.slf4j import Logger, LoggerFactory
from openhab import osgi
from openhab.rules import rule
from openhab.triggers import when
import openhab.rules
reload(openhab.rules)
import openhab.triggers
reload(openhab.triggers)
ruleEngine = osgi.get_service("org.eclipse.smarthome.automation.RuleManager")
class GroupLister:
def __init__(self, instName):
self.__name__ = instName
self.logger = LoggerFactory.getLogger("org.eclipse.smarthome.model.script.Rules.%s" %
self.__class__.__name__)
self.logger.info("Instantiating instance of class %s" %
def __call__(self, event):
self.logger.info("'%s' action (Jython cron rule)" % self.__name__)
self.logger.info("All Group items:")
for gItem in sorted(item for item in ir.getItemsOfType("Group"),
key = lambda item: item.name):
self.logger.info("==> %s" % gItem)
map(lambda mbr: self.logger.info(" |-- %s" % mbr),
sorted(gMbr for gMbr in gItem.members,
key = lambda mItem: mItem.name))
ruleEngine.setEnabled(self.UID, False) # one-shot rule
logger = LoggerFactory.getLogger("org.eclipse.smarthome.model.script.jsr223")
# requires rule and when imports
ruleInst1 = rule("Group Test Rule")(
when("Time cron 10 0/1 * * * ?")(
GroupLister("ruleInst1")))
logger.info("ruleInst1 attributes & methods: %s" % dir(ruleInst1))
Note that this code was written before ESH was reintegrated into OH, it likely needs some modifications to work with the latest 2.5.0-SNAPSHOTs.
Does getType() return “Group” or “Number”? If “Group”, how/can I determine if the Group is a “Number”? If “Number”, how/can I determine if the Number is also a Group?
