I have this rule that controls a fan in my bathroom based on humidity. The logic is to run the fan as long as FM_Kj_Badrom_Vegg > 40 and when it drops below 40 run a timer (600 seconds) and then stop the fan. The reason for the timer is to prevent flapping.
Now for some reason the function “def ventiler_kj_badrom_stopp()” never executes and I have absolutely no idea why
The debug log shows that the timer is started and after that I only get the log that the timer is already running. There’s no errors or anything in openhab.log either.
I have timers running in other scripts just fine, but this one refuses completely!
autoTimers = {}
@rule("ventiler badrom nede ved hoey luftfuktighet")
@when("Item FM_Kj_Badrom_Vegg changed")
def ventiler_kj_badrom(event):
if str(items.HouseAutoMode) == "ON":
if items.FM_Kj_Badrom_Vegg > DecimalType(40) and str(items.VV_Kj_Badrom) != "ON":
if "ventiler_kj_badrom" in autoTimers.keys(): # Reset running timer
autoTimers["ventiler_kj_badrom"].cancel()
del autoTimers["ventiler_kj_badrom"]
la.logDebug("jsrAutoRules",u"ventiler_kj_badrom: High humidity Kj_Badrom: {}, starting fan".format(items.FM_Kj_Badrom_Vegg))
events.sendCommand("VV_Kj_Badrom", "ON")
elif items.FM_Kj_Badrom_Vegg < DecimalType(40) and str(items.VV_Kj_Badrom) == "ON":
if not "ventiler_kj_badrom" in autoTimers.keys():
la.logDebug("jsrAutoRules",u"ventiler_kj_badrom: Low humidity, stopping fan in 600 seconds")
autoTimers["ventiler_kj_badrom"] = Timer(600, lambda: ventiler_kj_badrom_stopp())
else:
la.logDebug("jsrAutoRules",u"ventiler_kj_badrom: Low humidity, stoptimer already running, ignoring")
def ventiler_kj_badrom_stopp():
la.logDebug("jsrAutoRules",u"ventiler_kj_badrom: DEBUG REMOVING TIMER")
del autoTimers["ventiler_kj_badrom"] # Cleanup
events.sendCommand("VV_Kj_Badrom", "OFF")
la.logDebug("jsrAutoRules",u"ventiler_kj_badrom: Humidity normalised, ventilation stopped")
Log output:
04-Apr-2020 08:09:11.876 [DEBUG] [org.eclipse.smarthome.model.script.jsrAutoRules ] - ventiler_kj_badrom: Low humidity, stopping fan in 600 seconds
04-Apr-2020 08:13:19.878 [DEBUG] [org.eclipse.smarthome.model.script.jsrAutoRules ] - ventiler_kj_badrom: Low humidity, stoptimer already running, ignoring
04-Apr-2020 08:24:41.897 [DEBUG] [org.eclipse.smarthome.model.script.jsrAutoRules ] - ventiler_kj_badrom: Low humidity, stoptimer already running, ignoring # <-THE TIMER/FUNCTION SHOULD HAVE RUN BY NOW
