I have a motion sensor that sends both ON and OFF. In the case where an ON is sent, and the motion timer is running, I want to cancel the timer. So far, so good. When the motion detector sees an OFF later, it should start the timer again. But the code below reschedules the timer.
If I cancel a timer, should the hasTerminated() return true? I thought it would, but maybe not? The code below works because the reschedule starts the timer again, but this is not the path that I was expecting.
I’ve run HallMotionTimer.cancel(), so why doesn’t this line return true?:
if HallMotionTimer is None or HallMotionTimer.hasTerminated():
full code below:
HallMotionTimer = None
@rule("Motion Detection ON", description="actions for motion detection", tags=[])
@when("Item HallMotion changed to ON")
def MotionDetectedOn(event):
# away or vaction motion
global HallMotionTimer
if items["HouseMode"] == DecimalType(1):
MotionDetectedOn.log.info("Motion detected by {}".format(event.itemName))
if not items["PuckHold"] == NULL:
events.sendCommand("PuckString", "PUCK_ON")
if HallMotionTimer is not None and not HallMotionTimer.hasTerminated():
MotionDetectedOn.log.info("cancelling hall motion off timer")
@rule("Motion Detection OFF", description="actions for motion detection", tags=[])
@when("Item HallMotion changed to OFF")
def MotionDetectedOff(event):
MotionDetectedOff.log.info("Motion not detected by {}".format(event.itemName))
MotionDetectedOff.log.info("Motion not detected by {}, off timer started".format(event.itemName))
HallMotionTimer = ScriptExecution.createTimer(DateTime.now().plusMinutes(3),
lambda: events.sendCommand("PuckString", "PUCK_OFF"))
else:
HallMotionTimer.reschedule(DateTime.now().plusMinutes(3))
MotionDetectedOff.log.info("Puck off timer reschedule")
