Could you please try and change your Java Version to Zulu 11 32-Bit.
Here is what our prerequisits say :
The 32-bit version of the JVM is recommended on ARM platforms such as the Raspberry Pi. The 32-bit JVM performs better on the ARM platform. Some add-ons use libraries that do not work with a 64-bit JVM on ARM.
Issues exist especially on usage of serial libraries, which seems to be your reason (Logs reports an RXTX issue)
I’ve switched to
openjdk version “11.0.13” 2021-10-19 LTS
OpenJDK Runtime Environment Zulu11.52+13-CA (build 11.0.13+8-LTS)
OpenJDK Client VM Zulu11.52+13-CA (build 11.0.13+8-LTS, mixed mode)
But I still get
Dez 27 16:17:12 kopf systemd[1]: Started openHAB instance, reachable at http://kopf:8080.
Dez 27 16:17:12 kopf systemd[1]: Started Frontail openHAB instance, reachable at http://kopf:9001.
Dez 27 16:18:08 kopf karaf[39105]: RXTX Warning: Removing stale lock file. /var/lock/LCK..ttyAMA0
Dez 27 16:18:08 kopf karaf[39105]: *** buffer overflow detected ***: terminated
Dez 27 16:18:08 kopf systemd[1]: openhab.service: Main process exited, code=killed, status=6/ABRT
Dez 27 16:18:08 kopf systemd[1]: openhab.service: Failed with result 'signal'.
Dez 27 16:18:08 kopf systemd[1]: openhab.service: Consumed 1min 30.012s CPU time.
Dez 27 16:18:13 kopf systemd[1]: openhab.service: Scheduled restart job, restart counter is at 1.
NOTE:
it seems not as simple just to switch the java version as I get now some new faults:
2021-12-27 16:26:23.592 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'systeminfo:computer:kopf': Unable to load library 'udev':
libudev.so: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
/lib/aarch64-linux-gnu/libudev.so.1.7.0: falsche ELF-Klasse: ELFCLASS64
Native library (linux-arm/libudev.so) not found in resource path (/usr/share/openhab/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.3.4.jar:/usr/share/openhab/runtime/lib/boot/org.apache.karaf.jaas.boot-4.3.4.jar:/usr/share/openhab/runtime/lib/boot/org.apache.karaf.main-4.3.4.jar:/usr/share/openhab/runtime/lib/boot/org.apache.karaf.specs.activator-4.3.4.jar:/usr/share/openhab/runtime/lib/boot/osgi.core-7.0.0.jar:/usr/share/openhab/runtime/lib/jdk9plus/istack-commons-runtime-3.0.10.jar:/usr/share/openhab/runtime/lib/jdk9plus/jakarta.xml.bind-api-2.3.3.jar:/usr/share/openhab/runtime/lib/jdk9plus/javax.annotation-api-1.3.2.jar:/usr/share/openhab/runtime/lib/jdk9plus/jaxb-runtime-2.3.3.jar:/usr/share/openhab/runtime/lib/jdk9plus/org.apache.servicemix.specs.activation-api-1.2.1-1.2.1_3.jar:/usr/share/openhab/runtime/lib/jdk9plus/txw2-2.3.3.jar)
