@sihui Yes, you are right. Maybe I have time on next weekend to investigate this… But I only can test karaf console commands, what they are doing exactly. If there are any changes in programcode neccessary, someone else has to do this…
@sihui @Kai
Here are my investigations:
I tested on Window10,(32bit and 64bit) with the following builds:
741 (=2.0.0-SNAPSHOT, there is no old 2.0.0 Online-Repo available anymore, but uninstall worked, leaving folder \userdata\tmp\mvn\org\openhab\binding\ untouched!)
2.0.0.RC1
798
850
858
896
903 (=with new Online-Repo!)
I tested 798,850,858,896 with “old url” of Online-Repo: → latest installed version of a binding always was: 2.1.0.201704261428 ((if I e.g. manually deleted folder \userdata\tmp\mvn\org\openhab\binding\org.openhab.binding.harmonyhub before!))
Then I changed path to “new url” of Online-Repo: → latest installed version of a binding: depending on the latest available build number (903,904,905,906,907,908,909), but it ever was the newest available!
All above builds have excatly the same behavior!
If a binding NEVER was installed before, both (“karaf console command” or PaperUI) installed the newest available version of the binding from Online-Repo!
But PaperUI does NOT recognize this if you use “karaf console commands” only!
Here are my examples with “HarmonyHub Binding”:
bundle:list
222 | Active | 80 | 2.1.0.201705011011 | HarmonyHub Binding
bundle:update 222 https://openhab.jfrog.io/openhab/online-repo-snapshot/2.1/org/openhab/binding/org.openhab.binding.harmonyhub/2.1.0-SNAPSHOT/org.openhab.binding.harmonyhub-2.1.0-SNAPSHOT.jar
bundle:list
222 | Active | 80 | 2.1.0.201705072117 | HarmonyHub Binding <---newest version!
\userdata\cache\org.eclipse.osgi\222\3\ bundleFile (created with newest version)
\userdata\tmp\mvn\org\openhab\binding\org.openhab.binding.harmonyhub\2.1.0-SNAPSHOT\org.openhab.binding.harmonyhub-2.1.0-SNAPSHOT.jar (not updated or changed!)
bundle:uninstall 222
\userdata\cache\org.eclipse.osgi\222\3\ bundleFile ← deleted
\userdata\cache\org.eclipse.osgi\222\3\ .delete (file created)
\userdata\tmp\mvn\org\openhab\binding\org.openhab.binding.harmonyhub\2.1.0-SNAPSHOT\org.openhab.binding.harmonyhub-2.1.0-SNAPSHOT.jar (not deleted, untouched!)
PaperUI:
HarmonyHub Binding recognized still as installed!
HarmonyHub Binding uninstalled (via PaperUI)
HarmonyHub Binding installed (via PaperUI)
bundle:list
249 | Active | 80 | 2.1.0.201705011011 | HarmonyHub Binding <---old version again, restored from \userdata\tmp\mvn\org\openhab\binding\org.openhab.binding.harmonyhub\2.1.0-SNAPSHOT\
PaperUI:
\userdata\cache\org.eclipse.osgi\249\ .delete (bundeFile deleted and .delete created)
Karaf console:
bundle:install https://openhab.jfrog.io/openhab/online-repo-snapshot/2.1/org/openhab/binding/org.openhab.binding.harmonyhub/2.1.0-NAPSHOT/org.openhab.binding.harmonyhub-2.1.0-SNAPSHOT.jar
bundle:list
250 | Installed | 80 | 2.1.0.201705072117 | HarmonyHub Binding
bundle:start 250
bundle:list
250 | Active | 80 | 2.1.0.201705072117 | HarmonyHub Binding <---newest version again!
\userdata\cache\org.eclipse.osgi\250\0\ bundleFile (created, newest version!)
\userdata\tmp\mvn\org\openhab\binding\org.openhab.binding.harmonyhub\2.1.0-SNAPSHOT\org.openhab.binding.harmonyhub-2.1.0-SNAPSHOT.jar (not deleted or overwritten!)
PaperUI:
HarmonyHub Binding recognized still as uninstalled!
bundle:list
250 | Active | 80 | 2.1.0.201705072117 | HarmonyHub Binding (still the newest version, installed from karaf console!)
251 | Installed | 80 | 2.1.0.201705011011 | HarmonyHub Binding (installed old version again, and it's doubled!!) <--this surely is wrong!!)
PaperUI:
HarmonyHub Binding uninstalled!
karaf console:
bundle:uninstall 250
bundle:list
both 250 and 251 are gone!
PaperUI:
HarmonyHub Binding installed!
bundle:list
252 | Active | 80 | 2.1.0.201705072117 | HarmonyHub Binding (installed with the newest version!)
\userdata\cache\org.eclipse.osgi\252\0\ bundleFile (created, newest version!)
\userdata\tmp\mvn\org\openhab\binding\org.openhab.binding.harmonyhub\2.1.0-SNAPSHOT\org.openhab.binding.harmonyhub-2.1.0-SNAPSHOT.jar (newest version!)
Conclusion:
karaf console commands do exactly what they should do.
bundle:uninstall (OK)
bundle:update (OK)
bundle:install (OK)
BUT, PaperUI does NOT recognize any changes!
PaperUI did an uninstalling, but newest version never was installed. It always installs version from “tmp”
If you delete this folder manually, the newest version is installed!
My recommendation if you want an update of a binding:
- Use PaperUI to uninstall a binding.
- Delete corresponding folder from \userdata\tmp\mvn\org\openhab\binding\
- Use PaperUI to install the binding again.
I cannot confirm, that simply an uninstall/install of a binding via PaperUI or via addons.cfg (to do an update) ever worked before!
