Hi there,
installed an OpenHabian on a new Raspberry Pi 4, 2GB. Once by the Openhabian Image manually with the most recent stable release and second via the Raspbi-Imager, also the most recent stable release.
Just from the initial setup, the webUI does not come up and I see these exceptions in the log:
2022-09-17 21:19:14.172 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
java.lang.IllegalStateException: Error initializing storage for Equinox container.
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:110)
at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:53)
at org.eclipse.osgi.launch.EquinoxFactory.newFramework(EquinoxFactory.java:35)
at org.eclipse.osgi.launch.EquinoxFactory.newFramework(EquinoxFactory.java:30)
at org.apache.karaf.main.Main.launch(Main.java:291)
at org.apache.karaf.main.Main.main(Main.java:183)
Caused by: java.io.IOException: Unable to create lock manager.
at org.eclipse.osgi.storagemanager.StorageManager.open(StorageManager.java:713)
at org.eclipse.osgi.storage.Storage.getChildStorageManager(Storage.java:2194)
at org.eclipse.osgi.storage.Storage.getInfoInputStream(Storage.java:2211)
at org.eclipse.osgi.storage.Storage.<init>(Storage.java:256)
at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:184)
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:108)
- Platform information:
- Hardware: Raspberry Pi 4, 2GB Ram, 32GB SSD
- OS: Raspbian 11 (openHABian)
- Java Runtime Environment: openjdk 11
- openHAB version: 3.3.0
- Issue of the topic: s.o.
