We can’t really see anything from this picture.
Could you ssh into the pi and copy and paste the error into the forum, please
Don’t forget to use code fences, Thanks
There might be someone on this forum who can help. But really, a kernel panic means some hardware driver on your system threw an error. This isn’t something that is directly related to OH since OH doesn’t run in kernel space.
I would expect only two sources for this error:
The SD card became corrupted at some point either because it is worn out or it has had the power pulled while the RPi was running.
Loss of power without sitting down the RPi first can corrupt a file system no matter what sort media it is. It’s it’s even more likely with flash based memory which also includes ssds.
A corrupt fine system doesn’t mean there is anything wrong with the SSD itself. But it can mean that parts of important files, like kernel modules, are corrupted.
