[kind of solved] Victron GX MQTT messages to OpenHab 3 unstable
oh. you meant a node-red module. Ok - yes, seems to use REST API!
ok, I’ll have a look into that, I’m 99,9% sure, I only import MQTT-values. And I get the feeling, that if my OH3 is somehow under “rapid fire” or can’t persist the values fast enough in my MySQL-database it will do the “receive/predict/changed”-stuff - but if that’s impossible code-wise, I’ll rest my case…
2021-07-28 15:13:59.090 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'MQTTWetterstationBinder_Aussentemperatur' received command 18.22
2021-07-28 15:13:59.106 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'MQTTWetterstationBinder_Aussentemperatur' predicted to become 18.22
2021-07-28 15:13:59.132 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'MQTTWetterstationBinder_Windchill' changed from 17.78 to 18.22
2021-07-28 15:13:59.137 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'MQTTWetterstationBinder_Aussentemperatur' changed from 17.78 °C to 18.22 °C
2021-07-28 15:13:59.140 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'MQTTWetterstationBinder_letztesUpdate' changed from 2021-07-28T14:13:32.931+0000 to 2021-07-28T14:13:59.077+0000
vs
2021-07-28 15:35:51.101 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'MQTTWetterstationBinder_Aussentemperatur' changed from 18.22 °C to 18.72 °C
2021-07-28 15:35:51.106 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'MQTTWetterstationBinder_Windchill' changed from 18.22 to 18.72
2021-07-28 15:35:51.108 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'MQTTWetterstationBinder_WindboenBeschreibung' changed from leiser Zug to still
2021-07-28 15:35:51.132 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'MQTTWetterstationBinder_letztesUpdate' changed from 2021-07-28T14:35:32.929+0000 to 2021-07-28T14:35:51.085+0000
…but slowly and steadily we’re definitely moving away from topic! :wink:
