Kitchen Timer
This is a widget to put a countdown timer on the HABpanel screen. The result is this:
Usage is self explanatory. It uses the MapDB persistence service to save the timer in the event of a refresh or restart.
You will need to have the MapDB persistence service installed along with the JavaScript Scripting Automation language.
You will need the kitchen-timer.js file saved in your $OPENHAB_CONF/automation/js/ directory. Mine is /etc/openhab/automation/js/kitchen-timer.js
const { rules, triggers, items } = require('openhab');
// KITCHEN TIMER
const ITEM_COMMAND   = 'KitchenTimer_Command';
const ITEM_REMAINING = 'KitchenTimer_Remaining';
const ITEM_DISPLAY   = 'KitchenTimer_Display';
const ITEM_STATE     = 'KitchenTimer_State';
const ITEM_END_EPOCH = 'KitchenTimer_EndEpoch';
const ITEM_ALARM     = 'KitchenTimer_Alarm';
// HELPER FUNCTIONS
function getNumber(itemName, defaultValue) {
    const value =
        Number(items.getItem(itemName).state);
    if (Number.isFinite(value)) {
        return value;
    return defaultValue;
function getString(itemName, defaultValue) {
    const value =
        String(items.getItem(itemName).state);
    if (
        value === 'NULL' ||
        value === 'UNDEF' ||
        value === ''
    return value;
// FORMAT SECONDS AS MM:SS
function formatTime(totalSeconds) {
    let seconds =
        Math.max(0, Math.floor(totalSeconds));
    const minutes =
        Math.floor(seconds / 60);
    const remainingSeconds =
        seconds % 60;
    return (
        String(minutes).padStart(2, '0') +
        String(remainingSeconds).padStart(2, '0')
// UPDATE DISPLAY
function updateDisplay(seconds) {
    seconds =
        Math.max(0, Math.floor(seconds));
    items
        .getItem(ITEM_REMAINING)
        .postUpdate(seconds);
    items
        .getItem(ITEM_DISPLAY)
        .postUpdate(formatTime(seconds));
// ALARM
function startAlarm() {
    console.info(
        'KITCHEN TIMER: Alarm ON'
    items
        .getItem(ITEM_ALARM)
        .postUpdate('ON');
function stopAlarm() {
    items
        .postUpdate('OFF');
// ADD MINUTES
function addMinutes(minutes) {
    stopAlarm();
    const state =
        getString(ITEM_STATE, 'STOPPED');
    const secondsToAdd =
        minutes * 60;
    // TIMER IS CURRENTLY RUNNING
    // Extend the end time instead of changing only the
    // remaining-seconds Item.
    if (state === 'RUNNING') {
        let endEpoch =
            getNumber(
                ITEM_END_EPOCH,
                Date.now()
        if (endEpoch < Date.now()) {
            endEpoch = Date.now();
        endEpoch +=
            secondsToAdd * 1000;
        items
            .getItem(ITEM_END_EPOCH)
            .postUpdate(endEpoch);
        const remaining =
            Math.max(
                0,
                Math.ceil(
                    (endEpoch - Date.now()) / 1000
        updateDisplay(remaining);
        console.info(
            'KITCHEN TIMER: Added ' +
            minutes +
            ' minute(s) while running'
        return;
    // TIMER IS STOPPED OR PAUSED
    let remaining =
        getNumber(
            ITEM_REMAINING,
            0
    remaining += secondsToAdd;
    if (state !== 'PAUSED') {
        items
            .getItem(ITEM_STATE)
            .postUpdate('READY');
    console.info(
        minutes +
        ' minute(s), now ' +
        formatTime(remaining)
// START TIMER
function startTimer() {
    const remaining =
        getNumber(
            ITEM_REMAINING,
            0
    // Don't start a timer with no time
    if (remaining <= 0) {
        console.info(
            'KITCHEN TIMER: START ignored - no time set'
        return;
    stopAlarm();
    const endEpoch =
        Date.now() +
        (remaining * 1000);
    items
    items
        .postUpdate('RUNNING');
    console.info(
        'KITCHEN TIMER: Started at ' +
// PAUSE TIMER
function pauseTimer() {
    const state =
        getString(
            ITEM_STATE,
            'STOPPED'
    if (state !== 'RUNNING') {
        console.info(
            'KITCHEN TIMER: PAUSE ignored - not running'
        return;
    const endEpoch =
        getNumber(
            ITEM_END_EPOCH,
            Date.now()
    const remaining =
        Math.max(
            0,
            Math.ceil(
    items
        .postUpdate(0);
    items
        .postUpdate('PAUSED');
    console.info(
        'KITCHEN TIMER: Paused at ' +
// RESET TIMER
function resetTimer() {
    stopAlarm();
    items
        .postUpdate(0);
    items
        .postUpdate('STOPPED');
    updateDisplay(0);
    console.info(
        'KITCHEN TIMER: Reset'
// TIMER FINISHED
function finishTimer() {
    items
        .postUpdate(0);
    items
        .postUpdate('FINISHED');
    updateDisplay(0);
    startAlarm();
    console.info(
        'KITCHEN TIMER: Finished'
// HABPANEL COMMAND HANDLER
// IMPORTANT:
// We know from testing your system that the event parameter
// does NOT expose the command in the expected location.
// HABPanel successfully updates KitchenTimer_Command, so this
// rule reads the Item state directly.
rules.JSRule({
    name: 'Kitchen Timer Commands',
    description:
        'Handles Kitchen Timer commands from HABPanel',
    triggers: [
        triggers.ItemCommandTrigger(
            ITEM_COMMAND
    execute: () => {
        const command =
            String(
                items
                    .getItem(ITEM_COMMAND)
                    .state
        console.info(
            'KITCHEN TIMER COMMAND: ' +
            command
        if (command === 'ADD1') {
            addMinutes(1);
        else if (command === 'ADD5') {
            addMinutes(5);
        else if (command === 'ADD10') {
            addMinutes(10);
        else if (command === 'ADD30') {
            addMinutes(30);
        else if (command === 'START') {
            startTimer();
        else if (command === 'PAUSE') {
            pauseTimer();
        else if (command === 'RESET') {
            resetTimer();
        else if (command === 'SILENCE') {
            stopAlarm();
            console.info(
                'KITCHEN TIMER: Alarm silenced'
// COUNTDOWN
// Executes once every second.
// Instead of simply subtracting 1 every second,
// remaining time is calculated from the stored ending
// timestamp.
// This prevents timer drift.
rules.JSRule({
    name: 'Kitchen Timer Countdown',
    description:
        'Updates Kitchen Timer remaining time',
    triggers: [
        triggers.GenericCronTrigger(
    execute: () => {
        const state =
            getString(
                ITEM_STATE,
                'STOPPED'
            return;
        const endEpoch =
            getNumber(
                ITEM_END_EPOCH,
                0
        // Something is wrong if there is
        // no stored end time.
        if (endEpoch <= 0) {
            console.warn(
                'KITCHEN TIMER: Running but no end time exists'
            resetTimer();
            return;
        const remaining =
            Math.max(
                0,
                Math.ceil(
            finishTimer();
        else {
// INITIALIZATION / OPENHAB STARTUP
rules.JSRule({
    name: 'Kitchen Timer Initialization',
    description:
        'Restores Kitchen Timer after openHAB startup',
    triggers: [
        triggers.SystemStartlevelTrigger(100)
    execute: () => {
        let state =
            getString(
                ITEM_STATE,
                'STOPPED'
        // Timer was running before restart
            const endEpoch =
                getNumber(
                    ITEM_END_EPOCH,
                    0
            const remaining =
                Math.max(
                    0,
                    Math.ceil(
                finishTimer();
            else {
                console.info(
                    'KITCHEN TIMER: Restored running timer at ' +
            return;
        // If not running, restore displayed remaining time
        const remaining =
            getNumber(
                ITEM_REMAINING,
                0
        // Handle uninitialized timer
        if (
            state === 'NULL' ||
            state === 'UNDEF' ||
            state === ''
            items
        console.info(
            'KITCHEN TIMER: Initialized at ' +
Along with the kitchen-timer.items file save in your $OPENHAB_CONF/items/ directory. Mine is /etc/openhab/items/timer.items
Number KitchenTimer_Remaining "Remaining [%d seconds]"
Number KitchenTimer_EndEpoch  "End time [%d]"
String KitchenTimer_Display   "Timer [%s]"
String KitchenTimer_State     "Timer state [%s]"
String KitchenTimer_Command   "Timer command [%s]"
Switch KitchenTimer_Alarm     "Timer alarm"
You will also need this added to your mapdb.persist file located in OPENHAB_CONF/persistence/. Mine is /etc/openhab/persistence/.
Items {
    KitchenTimer_Remaining : strategy = everyChange, restoreOnStartup
    KitchenTimer_EndEpoch  : strategy = everyChange, restoreOnStartup
    KitchenTimer_Display   : strategy = everyChange, restoreOnStartup
    KitchenTimer_State     : strategy = everyChange, restoreOnStartup
    KitchenTimer_Alarm     : strategy = everyChange, restoreOnStartup
You will need to create a new widget. In the settings tab you will need to add a setting. Type is string, ID is KitchenTimer_Command, and Default Value is KitchenTimer_Command. Name the widget Kitchen-Timer
<style>
.kitchen-timer-widget {
    box-sizing: border-box;
    width: 100%;
    height: 100%;
    min-height: 280px;
    padding: 18px;
    border-radius: 14px;
    background: #181818;
    color: white;
    text-align: center;
    font-family: Arial, Helvetica, sans-serif;
.kitchen-timer-title {
    margin-bottom: 4px;
    color: #dddddd;
    font-size: 20px;
    font-weight: bold;
    text-transform: uppercase;
.kitchen-timer-display {
    margin: 10px 0 4px 0;
    color: #00ff66;
    font-family: "Courier New", monospace;
    font-size: 72px;
    font-weight: bold;
    line-height: 1.1;
    text-align: center;
    text-shadow: 0 0 12px rgba(0, 255, 102, 0.55);
.kitchen-timer-status {
    min-height: 23px;
    margin-bottom: 12px;
    color: #bbbbbb;
    font-size: 15px;
    font-weight: bold;
    letter-spacing: 1px;
.kitchen-timer-button-row {
    display: flex;
    flex-wrap: wrap;
    justify-content: center;
    gap: 8px;
    margin: 8px 0;
.kitchen-timer-button {
    min-width: 74px;
    padding: 11px 14px;
    border: none;
    border-radius: 8px;
    outline: none;
    background-color: #444444;
    color: white !important;
    font-size: 16px;
    font-weight: bold;
    cursor: pointer;
    touch-action: manipulation;
.kitchen-timer-button:hover {
    filter: brightness(1.15);
.kitchen-timer-button:active {
    transform: scale(0.95);
.kitchen-timer-start {
    background-color: #249c48;
.kitchen-timer-pause {
    background-color: #e58a00;
.kitchen-timer-reset {
    background-color: #cc3333;
.kitchen-timer-silence {
    background-color: #7b3fc6;
.kitchen-timer-running {
    color: #00ff66;
.kitchen-timer-paused {
    color: #ffb52e;
.kitchen-timer-finished {
    color: #ff3333;
    text-shadow: 0 0 16px rgba(255, 0, 0, 0.9);
    animation: kitchen-timer-flash 0.6s infinite;
.kitchen-timer-alarm-message {
    margin: 10px 0;
    color: #ff3333;
    font-size: 20px;
    font-weight: bold;
@keyframes kitchen-timer-flash {
    0% {
        opacity: 1;
    50% {
        opacity: 0.2;
    100% {
        opacity: 1;
@media (max-width: 500px) {
        font-size: 54px;
        min-width: 65px;
        padding: 10px 11px;
        font-size: 14px;
</style>
<div class="kitchen-timer-widget">
    <div class="kitchen-timer-title">
        Kitchen Timer
    </div>
    <div class="kitchen-timer-display"
         ng-class="{
             'kitchen-timer-running':
                 itemValue('KitchenTimer_State') == 'RUNNING',
             'kitchen-timer-paused':
                 itemValue('KitchenTimer_State') == 'PAUSED',
             'kitchen-timer-finished':
                 itemValue('KitchenTimer_Alarm') == 'ON'
        {{itemValue('KitchenTimer_Display') || '00:00'}}
    </div>
    <div class="kitchen-timer-status">
        {{itemValue('KitchenTimer_State') || 'STOPPED'}}
    </div>
    <div class="kitchen-timer-button-row">
        <button type="button"
                class="kitchen-timer-button"
                ng-click="sendCmd('KitchenTimer_Command', 'ADD1')">
            +1 MIN
        </button>
                ng-click="sendCmd('KitchenTimer_Command', 'ADD5')">
            +5 MIN
        </button>
                ng-click="sendCmd('KitchenTimer_Command', 'ADD10')">
            +10 MIN
        </button>
                ng-click="sendCmd('KitchenTimer_Command', 'ADD30')">
            +30 MIN
        </button>
    </div>
                class="kitchen-timer-button kitchen-timer-start"
                ng-click="sendCmd('KitchenTimer_Command', 'START')">
            START
        </button>
                class="kitchen-timer-button kitchen-timer-pause"
                ng-click="sendCmd('KitchenTimer_Command', 'PAUSE')">
            PAUSE
        </button>
                class="kitchen-timer-button kitchen-timer-reset"
                ng-click="sendCmd('KitchenTimer_Command', 'RESET')">
            RESET
        </button>
    </div>
    <div ng-if="itemValue('KitchenTimer_Alarm') == 'ON'">
        <div class="kitchen-timer-alarm-message">
            TIMER FINISHED
        </div>
                class="kitchen-timer-button kitchen-timer-silence"
                ng-click="sendCmd('KitchenTimer_Command', 'SILENCE')">
            SILENCE ALARM
        </button>
        <audio autoplay loop>
            <source
                src="/static/kitchen-timer-alarm.mp3"
                type="audio/mpeg">
        </audio>
    </div>
</div>
You will also need an mp3 file to use as the alarm named kitchen-timer-alarm.mp3 saved in your $OPENHAB_CONF/html/ directory. Mine is /etc/openhab//html/
That looks good but I just say hey google set timer 10 minutes…
But I could use it for other things…
Thanks for the share.
Thanks! I hope people can use it.
Hi!
Perhaps it could be called “Personal Timer”—that would open up many other possibilities for its use.
I like the concept; it could be used whenever there’s a need to time a task (or tasks) within a specific duration—including tasks that need to be repeated either during or after a certain period.
One thing: wouldn’t it be better to place the sound file in “/etc/openhab/sounds”?
Thanks for the idea and for sharing this widget!
Thanks!. I put the sound file in the html directory because it uses the HTML audio event instead of an audio sink so it can be played by whatever browser is displaying it. I don’t know if audio can get the file from the sounds directory.
