NCO
(E. Gerland)
February 5, 2021, 10:16am
25
Moin,
actually you can change some items - and this enables you to control the heating to a certain extend.
For me that’s totally sufficient.
So, what I can control is:
Heat_HzSollDay
(Target Temp Day) and the same for Heat_HzSollNight
Furthermore I can switch the Heating OFF:
Heat_HzMode.sendCommand("night")
and ON:
Heat_HzMode.sendCommand("day")
This will result in Heating = OFF as long as the Night Target Temp is significantly lower than the actual temperature:
Heat_TempWoZi
The same is true for the WarmWater control (ON/OFF):
Heat_WWMode.sendCommand("on")
and
Heat_WWMode.sendCommand("off")
respectively.
Please note that its “on” and not ON, because it’s a string and not a switch item.
I hope this helps.
juelicher
(Juelicher)
February 8, 2021, 8:48pm
26
Thanks for the explanation!
Could you figure out a way to heat up the warm water reservoir just once, but leave it in automatic mode?
NCO
(E. Gerland)
February 9, 2021, 10:36am
27
You mean the same function like pressing the WarmWater button on the wallmounted control unit?
There is no such button, but I manage this by using the command below with a timer:
During night WW is OFF, but it will be set to ON with my alarm clock.
If I am home alone (or on weekends, because I get up early), I switch it OFF after 30 minutes.
If the entire family is at home, I leave it on for 90 minutes.
juelicher
(Juelicher)
February 9, 2021, 1:34pm
28
Yes, exactly. I use this quite often when I come home very late or get up very early.
So you have no schedule for warm water in the control unit of the heating and instead this is controlled by openHAB?. I was always hesitant to do it that way, because this has a very high potential for a conflict with my wife, in case it is not working…
NCO
(E. Gerland)
February 9, 2021, 2:14pm
29
I agree - the wife-acceptance-factor must not be damaged.
Actually I play around every now and then and right now, I just switch the hot water on, whenever my wife comes home.
c0rtez
(Soeren)
February 14, 2021, 4:31pm
30
Im still not able to get it running. absolut not item delivers any information or accepts any commands
This is it. Spend way to much time in this so I give up
Will delete binding and things and have to use separate buderus up… very sad
Thanks a lot for your help
NCO
(E. Gerland)
February 14, 2021, 6:16pm
31
I would like to help you to make it work, because I know that it sucks to have something around which supposed to be working well with OH, but it does not.
So I can assure you, that I am very happy with it and its stability.
However, I remember that is was sometimes needed to reset the KM200 and the Heating (in my case Buderus Logamax GB152 I believe).
Did you try to power down an up your KM200 (and Heater)?
Do you setup your items in text files as well?
EDIT:
By the way:
Did you activate the TRACE / DEBUG mode of this binding to dig deeper?
Markinus
(Markus)
January 17, 2022, 5:52pm
32
I’ve added a check into this binding if JCE is installed or not. If not then the binding will go into a configuration error. I’ts merged and will be available with the V3.3
I hope this will reduce the number of problems on the very first start.
Moin!
I am not sure if this post is still alive. I am new with openhab but trying to make my way through all.
Just now I added the km200 binding for my Buderus heater and everything is online.
But I am wondering why my channels, for example the temperature of the water, shows the same number all the time instead of the actual one.
I guess I have to make some changings at the channels but unfortunately I don’t know what to do.
I am using the UI at Openhabian 3
Thanks in advance
Sky
goldie
(Adam B)
March 2, 2022, 10:56am
34
have you ever figured out how to control/monitor the circulation pump?
Circulation heat loss is huge (1C/hour in the 300l tank => 350W in my case, if the pump is running 4x3 minutes/hour) I would like to start the pump only when it is really needed, eg motion in the bathroom.
thanks and br
Markus1
(Markus)
March 8, 2022, 9:55pm
35
I am searching for the same function, but could not find it at the channels. I think it’s not included
goldie
(Adam B)
March 26, 2022, 6:30pm
36
Yeah, yda I put a SHelly1 there in the boiler to be able to control the pump
Hi again!
It seems my binding is loosing connection very often and I have to pull the power on and off at the Lan connection at the central heating unit. Then it is running for 1 or 2 days until the next connection lost.
I tried to Google a solution and found something about the JCEpolicies which have to be updated.
Does anybody had the connection problems too and found a permanent solution?
Cheers
Sky
Hello @Markinus ,
I fear that the latest firmware 04.08.02 did break some things.
Before the binding was running rock solid (still does), but now some information is missing.
Currently I do not get the thing “heatsources” during discovery. This did remove e.g. “actualPower”, “actualDHWPower” and more.
Could you have a look ? Guess you received the firmware as well.
OH Version 3.2. Runing on PI4, installed from openHabian image, openJDK 32bit.
I stopped and restarted the gateway thing, this is the log of the service list the binding discovered (Had to strip the date and some common IDs so it fits into the byte limit):
14:35:43.317 [DEBUG] [KM200Device] - ##################################################################
14:35:43.319 [DEBUG] [KM200Device] - List of avalible services
14:35:43.320 [DEBUG] [KM200Device] - readable;writeable;recordable;virtual;type;service;value;allowed;min;max;unit
14:35:43.322 [DEBUG] [KM200Device] - List type: refEnum service: /heatingCircuits
14:35:43.324 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatingCircuits;;
14:35:43.325 [DEBUG] [KM200Device] - List type: refEnum service: /heatingCircuits/hc1
14:35:43.327 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatingCircuits/hc1;;
14:35:43.328 [DEBUG] [KM200Device] - List type: floatValue service: /heatingCircuits/hc1/roomtemperature
14:35:43.330 [DEBUG] [KM200Device] - 1;0;1;0;floatValue;/heatingCircuits/hc1/roomtemperature;-3276.8;;;;
14:35:43.332 [DEBUG] [KM200Device] - List type: floatValue service: /heatingCircuits/hc1/supplyTemperatureSetpoint
14:35:43.333 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatingCircuits/hc1/supplyTemperatureSetpoint;53.0;;;;
14:35:43.335 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/roomTempOffset
14:35:43.336 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/roomTempOffset;;
14:35:43.338 [DEBUG] [KM200Device] - List type: stringValue service: /heatingCircuits/hc1/activeSwitchProgram
14:35:43.339 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/heatingCircuits/hc1/activeSwitchProgram;A;A|B;;;
14:35:43.341 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/designTemp
14:35:43.343 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/designTemp;;
14:35:43.344 [DEBUG] [KM200Device] - List type: refEnum service: /heatingCircuits/hc1/temperatureLevels
14:35:43.346 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatingCircuits/hc1/temperatureLevels;;
14:35:43.347 [DEBUG] [KM200Device] - List type: floatValue service: /heatingCircuits/hc1/temperatureLevels/eco
14:35:43.349 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/heatingCircuits/hc1/temperatureLevels/eco;18.0;;5.0;20.5;C
14:35:43.351 [DEBUG] [KM200Device] - List type: floatValue service: /heatingCircuits/hc1/temperatureLevels/comfort2
14:35:43.352 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/heatingCircuits/hc1/temperatureLevels/comfort2;21.0;;18.5;30.0;C
14:35:43.354 [DEBUG] [KM200Device] - List type: floatValue service: /heatingCircuits/hc1/suWiThreshold
14:35:43.355 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/heatingCircuits/hc1/suWiThreshold;19.0;;10.0;30.0;C
14:35:43.357 [DEBUG] [KM200Device] - List type: stringValue service: /heatingCircuits/hc1/operationMode
14:35:43.358 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/heatingCircuits/hc1/operationMode;auto;auto|manual;;;
14:35:43.360 [DEBUG] [KM200Device] - List type: floatValue service: /heatingCircuits/hc1/fastHeatupFactor
14:35:43.362 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/heatingCircuits/hc1/fastHeatupFactor;0.0;;1.0;100.0;%
14:35:43.363 [DEBUG] [KM200Device] - List type: floatValue service: /heatingCircuits/hc1/currentRoomSetpoint
14:35:43.365 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatingCircuits/hc1/currentRoomSetpoint;21.0;;;;
14:35:43.366 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/heatCurveMax
14:35:43.368 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/heatCurveMax;;
14:35:43.369 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/roomInfluence
14:35:43.371 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/roomInfluence;;
14:35:43.373 [DEBUG] [KM200Device] - List type: stringValue service: /heatingCircuits/hc1/suWiSwitchMode
14:35:43.374 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/heatingCircuits/hc1/suWiSwitchMode;automatic;off|automatic|forced;;;
14:35:43.376 [DEBUG] [KM200Device] - List type: floatValue service: /heatingCircuits/hc1/pumpModulation
14:35:43.377 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatingCircuits/hc1/pumpModulation;100.0;;;;
14:35:43.379 [DEBUG] [KM200Device] - List type: stringValue service: /heatingCircuits/hc1/currentSuWiMode
14:35:43.380 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/heatingCircuits/hc1/currentSuWiMode;forced;off|forced|cooling;;;
14:35:43.382 [DEBUG] [KM200Device] - List type: refEnum service: /heatingCircuits/hc1/holidayMode
14:35:43.383 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatingCircuits/hc1/holidayMode;;
14:35:43.385 [DEBUG] [KM200Device] - List type: stringValue service: /heatingCircuits/hc1/holidayMode/activated
14:35:43.386 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/heatingCircuits/hc1/holidayMode/activated;;|hm1|hm2|hm3|hm4|hm5;;;
14:35:43.388 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/nextSetpoint
14:35:43.390 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/nextSetpoint;;
14:35:43.391 [DEBUG] [KM200Device] - List type: stringValue service: /heatingCircuits/hc1/switchProgramMode
14:35:43.393 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/heatingCircuits/hc1/switchProgramMode;levels;levels|absolute;;;
14:35:43.394 [DEBUG] [KM200Device] - List type: refEnum service: /heatingCircuits/hc1/switchPrograms
14:35:43.396 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatingCircuits/hc1/switchPrograms;;
14:35:43.397 [DEBUG] [KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/A
14:35:43.399 [DEBUG] [KM200Device] - 1;1;0;0;switchProgram;/heatingCircuits/hc1/switchPrograms/A;;
14:35:43.401 [DEBUG] [KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/A/eco
14:35:43.402 [DEBUG] [KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/A/eco;;
14:35:43.404 [DEBUG] [KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/A/nbrCycles
14:35:43.405 [DEBUG] [KM200Device] - 1;0;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/A/nbrCycles;;
14:35:43.407 [DEBUG] [KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/A/weekday
14:35:43.408 [DEBUG] [KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/A/weekday;;
14:35:43.410 [DEBUG] [KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/A/cycle
14:35:43.411 [DEBUG] [KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/A/cycle;;
14:35:43.413 [DEBUG] [KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/A/comfort2
14:35:43.414 [DEBUG] [KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/A/comfort2;;
14:35:43.416 [DEBUG] [KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/B
14:35:43.418 [DEBUG] [KM200Device] - 1;1;0;0;switchProgram;/heatingCircuits/hc1/switchPrograms/B;;
14:35:43.419 [DEBUG] [KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/B/eco
14:35:43.421 [DEBUG] [KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/B/eco;;
14:35:43.422 [DEBUG] [KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/B/nbrCycles
14:35:43.424 [DEBUG] [KM200Device] - 1;0;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/B/nbrCycles;;
14:35:43.425 [DEBUG] [KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/B/weekday
14:35:43.427 [DEBUG] [KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/B/weekday;;
14:35:43.428 [DEBUG] [KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/B/cycle
14:35:43.430 [DEBUG] [KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/B/cycle;;
14:35:43.432 [DEBUG] [KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/B/comfort2
14:35:43.433 [DEBUG] [KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/B/comfort2;;
14:35:43.435 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/heatCurveMin
14:35:43.436 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/heatCurveMin;;
14:35:43.438 [DEBUG] [KM200Device] - List type: floatValue service: /heatingCircuits/hc1/actualSupplyTemperature
14:35:43.439 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatingCircuits/hc1/actualSupplyTemperature;45.5;;;;
14:35:43.441 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/currentOpModeInfo
14:35:43.442 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/currentOpModeInfo;;
14:35:43.444 [DEBUG] [KM200Device] - List type: floatValue service: /heatingCircuits/hc1/temporaryRoomSetpoint
14:35:43.445 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/heatingCircuits/hc1/temporaryRoomSetpoint;-1.0;;5.0;30.0;C
14:35:43.447 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/timeToNextSetpoint
14:35:43.448 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/timeToNextSetpoint;;
14:35:43.450 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/controlType
14:35:43.452 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/controlType;;
14:35:43.453 [DEBUG] [KM200Device] - List type: refEnum service: /heatingCircuits/hc1/cooling
14:35:43.455 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatingCircuits/hc1/cooling;;
14:35:43.456 [DEBUG] [KM200Device] - List type: stringValue service: /heatingCircuits/hc1/status
14:35:43.458 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/heatingCircuits/hc1/status;ACTIVE;INACTIVE|ACTIVE;;;
14:35:43.460 [DEBUG] [KM200Device] - List type: refEnum service: /solarCircuits
14:35:43.461 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/solarCircuits;;
14:35:43.463 [DEBUG] [KM200Device] - List type: refEnum service: /system
14:35:43.464 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/system;;
14:35:43.466 [DEBUG] [KM200Device] - List type: stringValue service: /system/bus
14:35:43.467 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/system/bus;EMS2_0;No_Bus|EMS1_0|EMS2_0|CAN;;;
14:35:43.469 [DEBUG] [KM200Device] - List type: refEnum service: /system/appliance
14:35:43.470 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/system/appliance;;
14:35:43.472 [DEBUG] [KM200Device] - List type: floatValue service: /system/appliance/actualSupplyTemperature
14:35:43.473 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/system/appliance/actualSupplyTemperature;45.5;;;;
14:35:43.475 [DEBUG] [KM200Device] - List type: refEnum service: /system/sensors
14:35:43.476 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/system/sensors;;
14:35:43.478 [DEBUG] [KM200Device] - List type: refEnum service: /system/sensors/temperatures
14:35:43.480 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/system/sensors/temperatures;;
14:35:43.481 [DEBUG] [KM200Device] - List type: floatValue service: /system/sensors/temperatures/outdoor_t1
14:35:43.483 [DEBUG] [KM200Device] - 1;0;1;0;floatValue;/system/sensors/temperatures/outdoor_t1;15.4;;;;
14:35:43.484 [DEBUG] [KM200Device] - List type: floatValue service: /system/sensors/temperatures/chimney
14:35:43.486 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/system/sensors/temperatures/chimney;-3276.8;;;;
14:35:43.487 [DEBUG] [KM200Device] - List type: floatValue service: /system/sensors/temperatures/supply_t1_setpoint
14:35:43.489 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/system/sensors/temperatures/supply_t1_setpoint;0.0;;;;
14:35:43.491 [DEBUG] [KM200Device] - List type: floatValue service: /system/sensors/temperatures/supply_t1
14:35:43.492 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/system/sensors/temperatures/supply_t1;45.5;;;;
14:35:43.494 [DEBUG] [KM200Device] - List type: floatValue service: /system/sensors/temperatures/return
14:35:43.495 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/system/sensors/temperatures/return;-3276.8;;;;
14:35:43.497 [DEBUG] [KM200Device] - List type: floatValue service: /system/sensors/temperatures/hotWater_t2
14:35:43.498 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/system/sensors/temperatures/hotWater_t2;44.3;;;;
14:35:43.500 [DEBUG] [KM200Device] - List type: floatValue service: /system/sensors/temperatures/switch
14:35:43.501 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/system/sensors/temperatures/switch;-3276.8;;;;
14:35:43.503 [DEBUG] [KM200Device] - List type: stringValue service: /system/healthStatus
14:35:43.505 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/system/healthStatus;error;error|maintenance|ok;;;
14:35:43.506 [DEBUG] [KM200Device] - List type: floatValue service: /system/minOutdoorTemp
14:35:43.508 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/system/minOutdoorTemp;-13.0;;-35.0;10.0;C
14:35:43.509 [DEBUG] [KM200Device] - List type: refEnum service: /system/holidayModes
14:35:43.511 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/system/holidayModes;;
14:35:43.513 [DEBUG] [KM200Device] - List type: refEnum service: /system/holidayModes/hm5
14:35:43.514 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/system/holidayModes/hm5;;
14:35:43.516 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm5/startStop
14:35:43.517 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm5/startStop;2009-01-01/2009-01-01;;;;
14:35:43.519 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm5/hcMode
14:35:43.520 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm5/hcMode;ECO;AUTO_SAT|FIX_TEMP|OFF|ECO;;;
14:35:43.522 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /system/holidayModes/hm5/delete
14:35:43.524 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/system/holidayModes/hm5/delete;;
14:35:43.526 [DEBUG] [KM200Device] - List type: arrayData service: /system/holidayModes/hm5/assignedTo
14:35:43.528 [DEBUG] [KM200Device] - 1;1;0;0;arrayData;/system/holidayModes/hm5/assignedTo;;
14:35:43.530 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm5/dhwMode
14:35:43.531 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm5/dhwMode;OFF;OFF|TD_OFF;;;
14:35:43.533 [DEBUG] [KM200Device] - List type: refEnum service: /system/holidayModes/hm2
14:35:43.535 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/system/holidayModes/hm2;;
14:35:43.537 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm2/startStop
14:35:43.539 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm2/startStop;2009-01-01/2009-01-01;;;;
14:35:43.541 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm2/hcMode
14:35:43.542 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm2/hcMode;ECO;AUTO_SAT|FIX_TEMP|OFF|ECO;;;
14:35:43.544 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /system/holidayModes/hm2/delete
14:35:43.546 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/system/holidayModes/hm2/delete;;
14:35:43.548 [DEBUG] [KM200Device] - List type: arrayData service: /system/holidayModes/hm2/assignedTo
14:35:43.550 [DEBUG] [KM200Device] - 1;1;0;0;arrayData;/system/holidayModes/hm2/assignedTo;;
14:35:43.552 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm2/dhwMode
14:35:43.553 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm2/dhwMode;OFF;OFF|TD_OFF;;;
14:35:43.555 [DEBUG] [KM200Device] - List type: refEnum service: /system/holidayModes/hm1
14:35:43.557 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/system/holidayModes/hm1;;
14:35:43.559 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm1/startStop
14:35:43.560 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm1/startStop;2009-01-01/2009-01-01;;;;
14:35:43.562 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm1/hcMode
14:35:43.564 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm1/hcMode;AUTO_SAT;AUTO_SAT|FIX_TEMP|OFF|ECO;;;
14:35:43.566 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /system/holidayModes/hm1/delete
14:35:43.568 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/system/holidayModes/hm1/delete;;
14:35:43.569 [DEBUG] [KM200Device] - List type: arrayData service: /system/holidayModes/hm1/assignedTo
14:35:43.571 [DEBUG] [KM200Device] - 1;1;0;0;arrayData;/system/holidayModes/hm1/assignedTo;;
14:35:43.573 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm1/dhwMode
14:35:43.575 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm1/dhwMode;OFF;OFF|TD_OFF;;;
14:35:43.576 [DEBUG] [KM200Device] - List type: refEnum service: /system/holidayModes/hm4
14:35:43.578 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/system/holidayModes/hm4;;
14:35:43.580 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm4/startStop
14:35:43.582 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm4/startStop;2009-01-01/2009-01-01;;;;
14:35:43.584 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm4/hcMode
14:35:43.585 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm4/hcMode;ECO;AUTO_SAT|FIX_TEMP|OFF|ECO;;;
14:35:43.587 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /system/holidayModes/hm4/delete
14:35:43.589 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/system/holidayModes/hm4/delete;;
14:35:43.591 [DEBUG] [KM200Device] - List type: arrayData service: /system/holidayModes/hm4/assignedTo
14:35:43.592 [DEBUG] [KM200Device] - 1;1;0;0;arrayData;/system/holidayModes/hm4/assignedTo;;
14:35:43.594 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm4/dhwMode
14:35:43.596 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm4/dhwMode;OFF;OFF|TD_OFF;;;
14:35:43.598 [DEBUG] [KM200Device] - List type: refEnum service: /system/holidayModes/hm3
14:35:43.599 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/system/holidayModes/hm3;;
14:35:43.601 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm3/startStop
14:35:43.603 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm3/startStop;2009-01-01/2009-01-01;;;;
14:35:43.605 [DEBUG] [KM200Device] - List type: stringValue service: /system/holidayModes/hm3/hcMode
14:35:43.606 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm3/hcMode;ECO;AUTO_SAT|FIX_TEMP|OFF|ECO;;;
14:35:43.608 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /system/holidayModes/hm3/delete
14:35:43.610 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/system/holidayModes/hm3/delete;;
14:35:43.612 [DEBUG] [KM200Device] - List type: arrayData service: /system/holidayModes/hm3/assignedTo
14:35:43.613 [DEBUG] [KM200Device] - 1;1;0;0;arrayData;/system/holidayModes/hm3/assignedTo;;
14:35:43.615 [DEBUG] [KM200Device] - List type: stringValue service: /system/systemType
14:35:43.617 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/system/systemType;NSC_ICOM_GATEWAY;NSC_ICOM_GATEWAY;;;
14:35:43.619 [DEBUG] [KM200Device] - List type: stringValue service: /system/brand
14:35:43.623 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/system/brand;Junkers;unknown|Bosch|Junkers|Buderus|Nefit|Sieger|Tata|Dakon|Elm|Boulter|Vulcano|Worcester|British Gas|IVT|Geminox|Neckar|Zeus|Milton;;;
14:35:43.625 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /system/busReq
14:35:43.626 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/system/busReq;;
14:35:43.628 [DEBUG] [KM200Device] - List type: systeminfo service: /system/info
14:35:43.630 [DEBUG] [KM200Device] - 1;0;0;0;systeminfo;/system/info;;
14:35:43.632 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources
14:35:43.633 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources;;
14:35:43.635 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/chimneyTemperature
14:35:43.637 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/chimneyTemperature;-3276.8;;;;
14:35:43.639 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/nominalCHPower
14:35:43.641 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/nominalCHPower;24.0;;;;
14:35:43.643 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/energyMonitoring
14:35:43.644 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/energyMonitoring;;
14:35:43.646 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/energyMonitoring/minTankLevel
14:35:43.648 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/heatSources/energyMonitoring/minTankLevel;0.0;;0.0;135780000.0;kWh
14:35:43.650 [DEBUG] [KM200Device] - List type: stringValue service: /heatSources/energyMonitoring/startDateTime
14:35:43.652 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/heatSources/energyMonitoring/startDateTime;2022-01-31T16:27:30;;;;
14:35:43.654 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/energyMonitoring/maxTankLevel
14:35:43.655 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/heatSources/energyMonitoring/maxTankLevel;0.0;;0.0;135780000.0;kWh
14:35:43.657 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/energyMonitoring/consumption
14:35:43.659 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/heatSources/energyMonitoring/consumption;127266456.0;;0.0;135780000.0;kWh
14:35:43.661 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/energyMonitoring/correctionFactor
14:35:43.662 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/heatSources/energyMonitoring/correctionFactor;1.0;;0.7;1.3;
14:35:43.664 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/energyMonitoring/tankLevel
14:35:43.666 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/heatSources/energyMonitoring/tankLevel;0.0;;0.0;135780000.0;kWh
14:35:43.668 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/hs1
14:35:43.669 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/hs1;;
14:35:43.671 [DEBUG] [KM200Device] - List type: stringValue service: /heatSources/hs1/flameStatus
14:35:43.673 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/heatSources/hs1/flameStatus;off;off|on;;;
14:35:43.674 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/hs1/
14:35:43.676 [DEBUG] [KM200Device] - 1;0;1;0;floatValue;/heatSources/hs1/actualPower;0.00;;;;
14:35:43.678 [DEBUG] [KM200Device] - List type: stringValue service: /heatSources/hs1/type
14:35:43.679 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/heatSources/hs1/type;GasBoiler;No_Appliance|OilBoiler|GasBoiler|Heatpump|unknownBoiler;;;
14:35:43.681 [DEBUG] [KM200Device] - List type: systeminfo service: /heatSources/hs1/info
14:35:43.683 [DEBUG] [KM200Device] - 1;0;0;0;systeminfo;/heatSources/hs1/info;;
14:35:43.684 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/hs1/actualModulation
14:35:43.686 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/hs1/actualModulation;0.0;;;;
14:35:43.688 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/actualPower
14:35:43.689 [DEBUG] [KM200Device] - 1;0;1;0;floatValue;/heatSources/actualPower;0.0;;;;
14:35:43.691 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/supplyTemperatureSetpoint
14:35:43.693 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/supplyTemperatureSetpoint;0.0;;;;
14:35:43.694 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/numberOfStarts
14:35:43.696 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/numberOfStarts;79814;;;;
14:35:43.698 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/actualDHWPower
14:35:43.699 [DEBUG] [KM200Device] - 1;0;1;0;floatValue;/heatSources/actualDHWPower;0.0;;;;
14:35:43.701 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/powerSetpoint
14:35:43.702 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/powerSetpoint;63.0;;;;
14:35:43.704 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/burnerModulationSetpoint
14:35:43.705 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/burnerModulationSetpoint;63.0;;;;
14:35:43.707 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/electricGrid
14:35:43.708 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/electricGrid;;
14:35:43.710 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/total
14:35:43.711 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/total;;
14:35:43.713 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/total/energyMonitoring
14:35:43.714 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/total/energyMonitoring;;
14:35:43.716 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/burnerPowerSetpoint
14:35:43.717 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/burnerPowerSetpoint;15.0;;;;
14:35:43.719 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/returnTemperature
14:35:43.720 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/returnTemperature;-3276.8;;;;
14:35:43.722 [DEBUG] [KM200Device] - List type: systeminfo service: /heatSources/info
14:35:43.723 [DEBUG] [KM200Device] - 1;0;0;0;systeminfo;/heatSources/info;;
14:35:43.725 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/CHpumpModulation
14:35:43.726 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/CHpumpModulation;100.0;;;;
14:35:43.728 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/applianceSupplyTemperature
14:35:43.729 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/applianceSupplyTemperature;45.5;;;;
14:35:43.731 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/actualCHPower
14:35:43.732 [DEBUG] [KM200Device] - 1;0;1;0;floatValue;/heatSources/actualCHPower;0.0;;;;
14:35:43.734 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/fuelCell
14:35:43.735 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/fuelCell;;
14:35:43.737 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/ch
14:35:43.738 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/ch;;
14:35:43.740 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/ch/energyMonitoring
14:35:43.742 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/ch/energyMonitoring;;
14:35:43.744 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/pool
14:35:43.745 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/pool;;
14:35:43.747 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/pool/energyMonitoring
14:35:43.748 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/pool/energyMonitoring;;
14:35:43.750 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/workingTime
14:35:43.752 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/workingTime;;
14:35:43.754 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/workingTime/secondBurner
14:35:43.755 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/workingTime/secondBurner;0;;;;
14:35:43.757 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/workingTime/centralHeating
14:35:43.758 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/workingTime/centralHeating;1846879;;;;
14:35:43.760 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/workingTime/totalSystem
14:35:43.761 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/workingTime/totalSystem;2311461;;;;
14:35:43.763 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/actualSupplyTemperature
14:35:43.764 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/actualSupplyTemperature;45.5;;;;
14:35:43.766 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/dhw
14:35:43.767 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/dhw;;
14:35:43.769 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/dhw/energyMonitoring
14:35:43.770 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/dhw/energyMonitoring;;
14:35:43.772 [DEBUG] [KM200Device] - List type: refEnum service: /heatSources/sensors
14:35:43.773 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/heatSources/sensors;;
14:35:43.775 [DEBUG] [KM200Device] - List type: stringValue service: /heatSources/flameStatus
14:35:43.776 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/heatSources/flameStatus;off;off|on;;;
14:35:43.778 [DEBUG] [KM200Device] - List type: stringValue service: /heatSources/ChimneySweeper
14:35:43.779 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/heatSources/ChimneySweeper;off;;;;
14:35:43.781 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/gasAirPressure
14:35:43.782 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/gasAirPressure;0.0;;;;
14:35:43.784 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/systemPressure
14:35:43.785 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/systemPressure;25.5;;;;
14:35:43.787 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/actualModulation
14:35:43.788 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/actualModulation;0.0;;;;
14:35:43.790 [DEBUG] [KM200Device] - List type: floatValue service: /heatSources/nominalDHWPower
14:35:43.791 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/heatSources/nominalDHWPower;24.0;;;;
14:35:43.793 [DEBUG] [KM200Device] - List type: refEnum service: /dhwCircuits
14:35:43.794 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/dhwCircuits;;
14:35:43.796 [DEBUG] [KM200Device] - List type: refEnum service: /dhwCircuits/dhw1
14:35:43.797 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/dhwCircuits/dhw1;;
14:35:43.799 [DEBUG] [KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/waterFlow
14:35:43.800 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/dhwCircuits/dhw1/waterFlow;0.0;;;;
14:35:43.802 [DEBUG] [KM200Device] - List type: stringValue service: /dhwCircuits/dhw1/operationMode
14:35:43.803 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/dhwCircuits/dhw1/operationMode;ownprogram;Off|low|high|HCprogram|ownprogram;;;
14:35:43.805 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /dhwCircuits/dhw1/tdsetPoint
14:35:43.806 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/dhwCircuits/dhw1/tdsetPoint;;
14:35:43.808 [DEBUG] [KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/singleChargeSetpoint
14:35:43.809 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/dhwCircuits/dhw1/singleChargeSetpoint;60.0;;30.0;80.0;C
14:35:43.811 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /dhwCircuits/dhw1/cpStartph
14:35:43.812 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/dhwCircuits/dhw1/cpStartph;;
14:35:43.814 [DEBUG] [KM200Device] - List type: refEnum service: /dhwCircuits/dhw1/holidayMode
14:35:43.815 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/dhwCircuits/dhw1/holidayMode;;
14:35:43.817 [DEBUG] [KM200Device] - List type: stringValue service: /dhwCircuits/dhw1/holidayMode/activated
14:35:43.818 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/dhwCircuits/dhw1/holidayMode/activated;;|hm1|hm2|hm3|hm4|hm5;;;
14:35:43.820 [DEBUG] [KM200Device] - List type: refEnum service: /dhwCircuits/dhw1/switchPrograms
14:35:43.821 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/dhwCircuits/dhw1/switchPrograms;;
14:35:43.823 [DEBUG] [KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/A
14:35:43.824 [DEBUG] [KM200Device] - 1;1;0;0;switchProgram;/dhwCircuits/dhw1/switchPrograms/A;;
14:35:43.825 [DEBUG] [KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/A/high
14:35:43.827 [DEBUG] [KM200Device] - 1;1;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/A/high;;
14:35:43.828 [DEBUG] [KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/A/low
14:35:43.830 [DEBUG] [KM200Device] - 1;1;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/A/low;;
14:35:43.831 [DEBUG] [KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/A/nbrCycles
14:35:43.833 [DEBUG] [KM200Device] - 1;0;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/A/nbrCycles;;
14:35:43.834 [DEBUG] [KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/A/weekday
14:35:43.836 [DEBUG] [KM200Device] - 1;1;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/A/weekday;;
14:35:43.837 [DEBUG] [KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/A/cycle
14:35:43.839 [DEBUG] [KM200Device] - 1;1;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/A/cycle;;
14:35:43.840 [DEBUG] [KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/currentSetpoint
14:35:43.842 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/dhwCircuits/dhw1/currentSetpoint;50.0;;;;
14:35:43.843 [DEBUG] [KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/actualTemp
14:35:43.845 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/dhwCircuits/dhw1/actualTemp;44.3;;;;
14:35:43.846 [DEBUG] [KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/workingTime
14:35:43.848 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/dhwCircuits/dhw1/workingTime;226622;;;;
14:35:43.849 [DEBUG] [KM200Device] - List type: refEnum service: /dhwCircuits/dhw1/temperatureLevels
14:35:43.851 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/dhwCircuits/dhw1/temperatureLevels;;
14:35:43.852 [DEBUG] [KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/temperatureLevels/high
14:35:43.854 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/dhwCircuits/dhw1/temperatureLevels/high;50.0;;45.0;80.0;C
14:35:43.855 [DEBUG] [KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/temperatureLevels/low
14:35:43.857 [DEBUG] [KM200Device] - 1;1;0;0;floatValue;/dhwCircuits/dhw1/temperatureLevels/low;45.0;;15.0;50.0;C
14:35:43.858 [DEBUG] [KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/temperatureLevels/off
14:35:43.860 [DEBUG] [KM200Device] - 1;0;0;0;floatValue;/dhwCircuits/dhw1/temperatureLevels/off;0.0;;;;
14:35:43.861 [DEBUG] [KM200Device] - List type: stringValue service: /dhwCircuits/dhw1/status
14:35:43.863 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/dhwCircuits/dhw1/status;ACTIVE;INACTIVE|ACTIVE;;;
14:35:43.864 [DEBUG] [KM200Device] - List type: refEnum service: /gateway
14:35:43.866 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/gateway;;
14:35:43.867 [DEBUG] [KM200Device] - List type: stringValue service: /gateway/versionFirmware
14:35:43.869 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/gateway/versionFirmware;04.08.02;;;;
14:35:43.870 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /gateway/instPassword
14:35:43.871 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/instPassword;;
14:35:43.873 [DEBUG] [KM200Device] - List type: stringValue service: /gateway/instAccess
14:35:43.874 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/gateway/instAccess;off;off|on;;;
14:35:43.876 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /gateway/boschSHPassword
14:35:43.877 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/boschSHPassword;;
14:35:43.879 [DEBUG] [KM200Device] - List type: stringValue service: /gateway/versionHardware
14:35:43.880 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/gateway/versionHardware;iCom_Low_NSC_v1;;;;
14:35:43.882 [DEBUG] [KM200Device] - List type: refEnum service: /gateway/update
14:35:43.883 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/gateway/update;;
14:35:43.885 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /gateway/update/request
14:35:43.886 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/update/request;;
14:35:43.888 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /gateway/update/strategy
14:35:43.889 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/update/strategy;;
14:35:43.891 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /gateway/update/version
14:35:43.892 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/update/version;;
14:35:43.894 [DEBUG] [KM200Device] - List type: stringValue service: /gateway/update/status
14:35:43.895 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/gateway/update/status;completed;inprogress|completed|interrupted;;;
14:35:43.897 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /gateway/portalPassword
14:35:43.898 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/portalPassword;;
14:35:43.900 [DEBUG] [KM200Device] - List type: stringValue service: /gateway/uuid
14:35:43.902 [DEBUG] [KM200Device] - 1;0;0;0;stringValue;/gateway/uuid;XXXXXXXXX;XXXXXXXXX;;;
14:35:43.904 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /gateway/knxPassword
14:35:43.906 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/knxPassword;;
14:35:43.908 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /gateway/version
14:35:43.910 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/version;;
14:35:43.911 [DEBUG] [KM200Device] - List type: stringValue service: /gateway/DateTime
14:35:43.912 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/gateway/DateTime;2022-03-28T14:32:34;;;;
14:35:43.914 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /gateway/userpassword
14:35:43.915 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/userpassword;;
14:35:43.916 [DEBUG] [KM200Device] - List type: stringValue service: /gateway/instWriteAccess
14:35:43.918 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/gateway/instWriteAccess;off;off|on;;;
14:35:43.919 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /gateway/haiPassword
14:35:43.920 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/haiPassword;;
14:35:43.922 [DEBUG] [KM200Device] - List type: refEnum service: /gateway/logging
14:35:43.923 [DEBUG] [KM200Device] - 1;0;0;0;refEnum;/gateway/logging;;
14:35:43.924 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /gateway/logging/reqBusVar
14:35:43.926 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/logging/reqBusVar;;
14:35:43.927 [DEBUG] [KM200Device] - List type: stringValue service: /gateway/logging/userAcceptance
14:35:43.928 [DEBUG] [KM200Device] - 1;1;0;0;stringValue;/gateway/logging/userAcceptance;false;false|true;;;
14:35:43.930 [DEBUG] [KM200Device] - List type: $$PROTECTED$$ service: /gateway/logging/switch
14:35:43.931 [DEBUG] [KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/logging/switch;;
14:35:43.932 [DEBUG] [KM200Device] - List type: errorList service: /notifications
14:35:43.934 [DEBUG] [KM200Device] - 1;0;0;0;errorList;/notifications;;
14:35:43.935 [DEBUG] [KM200Device] - List type: errorList service: /notifications/nbrErrors
14:35:43.936 [DEBUG] [KM200Device] - 1;0;0;1;errorList;/notifications/nbrErrors;;
14:35:43.938 [DEBUG] [KM200Device] - List type: errorList service: /notifications/errorString
14:35:43.939 [DEBUG] [KM200Device] - 1;0;0;1;errorList;/notifications/errorString;;
14:35:43.940 [DEBUG] [KM200Device] - List type: errorList service: /notifications/error
14:35:43.941 [DEBUG] [KM200Device] - 1;1;0;1;errorList;/notifications/error;;
14:35:43.943 [DEBUG] [KM200Device] - ##################################################################
14:35:43.956 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:holidayMode
14:35:43.956 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:heatingCircuit
14:35:43.957 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:holidayMode
14:35:43.968 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:holidayMode
14:35:43.971 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:holidayMode
14:35:44.003 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
14:35:44.007 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
14:35:44.008 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
14:35:44.062 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
14:35:44.067 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:sensor
14:35:44.085 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:system
14:35:44.088 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
14:35:44.117 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
14:35:44.153 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
14:35:44.418 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:holidayMode
14:35:44.428 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:appliance
14:35:44.433 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:notification
14:35:44.444 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:dhwCircuit
14:35:44.449 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
14:35:44.458 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:heatingCircuit
14:35:44.459 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
14:35:44.469 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:dhwCircuit
14:35:44.490 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
14:35:44.491 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
14:35:44.493 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
14:35:44.513 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
14:35:44.751 [DEBUG] [g.km200.internal.KM200HandlerFactory] - It's a thing: km200:gateway
14:35:44.804 [DEBUG] [0.internal.handler.KM200ThingHandler] - initialize, Bridge: org.openhab.core.thing.internal.BridgeImpl@7029b777
EDIT: I had to delete the thing, scanned, did not get results. Two says later tried again, thing was discovered. So I’m back in the saddle.
Strange behaviour.
Regards,
Thomas
Blackeye55
(David Jayne)
September 23, 2022, 12:31pm
39
Back to the original subject of the thread:
We recently had solar thermal panels and a KM200 gateway installed. So far, I have not been able to use the binding because I am not able to generate the key. The website of Andreas Hahn, suggested by NCO back in Feb 2017 is no longer active.
My Java is version 11 which has the unlimited policy active as standard, I read elswhere.
So my question is: how do I generate the private key now?
Thanks for any help here!
gs4711
(Guenther Schreiner)
September 23, 2022, 4:50pm
40
See code example refered in this topic .
Blackeye55
(David Jayne)
September 25, 2022, 10:22am
41
Many thanks Günther! You have found the solution! I have spent many hours creating salty hashes with magic bytes and keys of all sorts … (Seufze) I wish we could DELETE out-of-date and inaccurate posts from the Internet that lead people down the wrong path when they are looking for solutions, and there are many on this subject! Thank you!
c0rtez
(Soeren)
November 22, 2022, 8:47pm
42
Hey everyone, would like to ask if someone by now find a solution to find all possible items? Channel still doesn’t deliver anything. So until now I used what I found in the post of @NCO but not everything seems to deliver correct information. So for example:
km200:sensor:heizunggateway:temperatures:supply_t1 - From my understanding is the water temp
and
km200:heatingCircuit:heizunggateway:hc1:actualSupplyTemperature - Should be the temperature (outgoing) in the heating circut (in german “Vorlauftemperatur”)
But both delivering the exact same value all the time.
So it would be really helpful to have an overview of all possible items and what information they deliver. The official documentation says that channels should come automatically but it’s not the case for me.
BratHuhn
(BratHuhn)
December 8, 2022, 4:57pm
43
The add-on checks all routes on the REST endpoint. When there is no entry discovered then the km200 doesn’t offer one. I had the same issue and like I wrote in the other issue the only way getting all relevant values out of it is by hopping on the internal bus system. (Binding Request : Buderus web gateway - #528 by BratHuhn )
mcarco
(Marco Geh.)
May 4, 2023, 10:09pm
44
there is an updated Website to generate the secret key!
https://km200.andreashahn.info/
