Firstly thank you for your work!
I relatively technically minded, but quite new in the field of Linux (dabbled by never went far), so when I encounter errors it’s a concern. I was relatively sure it was a catch-all command line but had to make sure.
[quote=“ThomDietrich, post:12, topic:17892”]
Regarding openHABian: I totally get what you are trying to say by hands-off. I can however ensure you that openHABian is just an automation of the recommended steps after setting up Raspbian. After the first boot the system is under your full control and you can use and modify it however you want to.
[/quote]Yes it’s a great script, though once again watching it install you get presented with quite a few warning/errors. That you hope aren’t too much of an issue. Though it took my install around 3 hours to complete (an option for an online install version might speed that).
I had previously installed via the Raspberry/Linux installation instructions, which I’ve gone back too. So when I tried the openHABian solution, though it was good for things like disabling root, and installing various helper tools. As a newbie, the command line interface can be quite daunting. At this stage I liked the ease of the GUI interface that is default in the apt-get method. Where things like correcting the wrong keyboard layout settings, or even the raspi-config interface is easier to manage for a newbie.
I’ve now set the configurations to how I want them, memory to 16 and I can even set it to start to the command line when I’m pure headless.
Regarding your more general questions/concerns: You are mentioning many details that were interesting with openHAB 1.x but are not with openHAB 2. That’s why I believe your actual problem was to look into old OH1 tutorials. I believe if you just follow the articles under http://docs.openhab.org you will be fine.
[/quote]Yes, the majority of the guides outside of the ‘docs.openhab’ are more in line with 1.x. Where looking for features and options that are moved or depreciated in 2.x can cause the issues. I think some of the contents of migration from 1.x should be duplicated in a ‘New to HAB 2.x’ section or something as that helped a bit. I try to only look at the HAB2 docs section for information, but some of that is a little light.
Like the sitemap section mentions it comes with a demo configuration package, but no direct way to access that from a base install. As not mentioned in that section you need to alter the addons.cfg or use Paper UI to set it to demo and, I think, either wait or restart the service to get the demo site installed/configured. Which I found out afterwards.
That said, your input on missing information in this still young documentation platform would be amazing! Tell us about them here or in the GitHub Issue tracker. It might be interesting for you to also look at the big menu rework I’m currently working on.
[/quote]Thanks I’ll try and, as a newbie, document any issues or little knowledge gaps I’ve encountered. Than might help those also new to openHAB.
I’ll try to take a look at the big rework, I don’t envy you regarding documentation. One of my pet hates. Good luck!!
