Dear Community,
I’m facing issues when configuring rollershutter in OH2.
(Same setup is working fine with OH1).
Command UP and DOWN are triggered and sent on the bus.
STOP command only appears as ItemCommandEvent, but no value written on the bus.
This is my configuration:
Type rollershutter-control : R_OG_AR_01 "Rollo Arbeit OG" [ upDown="1/4/30", stopMove="1/4/31", position="5.001:1/4/32+<1/4/36"]
Rollershutter ROGAR01_Test "Rollladen Arbeit OG" {channel="knx:device:bridgeRS:generic:R_OG_AR_01"}
Log trace for UP command
13:44:50.519 [TRACE] [smarthome.event.ItemCommandEvent ] - Received event of type 'ItemCommandEvent' under the topic 'smarthome/items/ROGAR01_Test/command' with payload: '{"type":"UpDown","value":"UP"}'
13:44:50.533 [TRACE] [x.internal.handler.DeviceThingHandler] - Handling command 'UP' for channel 'knx:device:bridgeRS:generic:R_OG_AR_01'
13:44:50.562 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'ROGAR01_Test' received command UP
13:44:50.610 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value 'UP' to datapoint 'command DP 3/1/30 'knx:ip:bridgeRS', DPT id 1.008, low priority' (0. attempt).
13:44:53.713 [TRACE] [knx.internal.client.Abstr
Log trace for STOP command:
13:45:30.980 [TRACE] [smarthome.event.ItemCommandEvent ] - Received event of type 'ItemCommandEvent' under the topic 'smarthome/items/ROGAR01_Test/command' with payload: '{"type":"StopMove","value":"STOP"}'
13:45:31.015 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'ROGAR01_Test' received command STOP
Maybe someone could point me in the right direction?
Many thanks for your help,
Peter
