Hi There,
I’m running a oh2 installation “in Background” for testing and migration. Most time I’m looking at this system, knx 2 binding is down and all things are down. In the logs I see this warnings and the
“negative confirmation” messages is repeated thousand times.
The KNX bus connection is stable - I have a OH1 setup running without any problems.
After reboot, knx 2 binding works like a charm for a few days.
Any suggestions?
2018-08-16 15:02:33.276 [WARN ] [et/IP Tunneling 192.168.178.200:3671] - response timeout waiting for confirmation
tuwien.auto.calimero.KNXTimeoutException: no confirmation reply received for 0.0.0->1.1.25 L_Data.req, system priority hop count 6 repeat, tpdu 81
at tuwien.auto.calimero.knxnetip.ClientConnection.doExtraBlockingModes(ClientConnection.java:244) ~[198:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.knxnetip.ConnectionBase.send(ConnectionBase.java:258) ~[198:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.send(KNXnetIPTunnel.java:178) ~[198:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.onSend(KNXNetworkLinkIP.java:243) ~[198:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.link.AbstractLink.send(AbstractLink.java:351) ~[198:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.sendRequestWait(KNXNetworkLinkIP.java:222) ~[198:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.sendDisconnect(TransportLayerImpl.java:612) ~[198:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.handleConnected(TransportLayerImpl.java:510) ~[198:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.access$400(TransportLayerImpl.java:87) ~[198:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.mgmt.TransportLayerImpl$NLListener.indication(TransportLayerImpl.java:127) ~[198:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.link.AbstractLink$LinkNotifier.lambda$frameReceived$1(AbstractLink.java:159) ~[198:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.internal.EventListeners.fire(EventListeners.java:129) [198:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.link.EventNotifier.fire(EventNotifier.java:164) [198:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.link.EventNotifier.run(EventNotifier.java:101) [198:org.openhab.binding.knx:2.3.0]
2018-08-16 15:02:33.277 [WARN ] [alimero.mgmt.TL 192.168.178.200:3671] - disconnected not gracefully (timeout)
2018-08-16 15:07:25.542 [WARN ] [calimero.link.192.168.178.200:3671 ] - negative confirmation of 1.1.1: 2e009160fffc11010080
2018-08-16 15:07:25.614 [WARN ] [calimero.link.192.168.178.200:3671 ] - negative confirmation of 1.1.1: 2e009d60fffc1101014300
2018-08-16 15:07:28.686 [WARN ] [calimero.link.192.168.178.200:3671 ] - negative confirmation of 1.1.1: 2e009d60fffc1101014300
2018-08-16 15:07:31.759 [WARN ] [calimero.link.192.168.178.200:3671 ] - negative confirmation of 1.1.1: 2e009d60fffc1101014300
