rule "Message if Blinds UP"
Item RLHausAlle received command UP
sendTelegram("bot1","Rolläden im ganzen Haus am "+ Date.state.format("%1$td.%1$tm.%1$tY") +" um " + Date.state.format("%1$tH:%1$tM") + " geöffnet")
rule "Message if Blinds DOWN"
Item RLHausAlle received command DOWN
sendTelegram("bot1","Rolläden im ganzen Haus am "+ Date.state.format("%1$td.%1$tm.%1$tY") +" um " + Date.state.format("%1$tH:%1$tM") + " geschlossen")
As with KNX2, the “received command” is not supported by the non-Control-items, so am not sure how to work around that. If my logic triggers the blinds, it uses the RLHausAlles item. In case I needed to define something like RLHausAlles-Control-Item then I would Need an additional rule to modify the Control-item, as it would not get fired by the RLHausAlles command, as far as I understand this. Can somebody give a hint how to deal with this?
rule "Test ON"
Item LichtUnterschrankNord received update ON
LichtKueche.sendCommand (ON)
rule "Test OFF"
Item LichtUnterschrankNord received update OFF
LichtKueche.sendCommand (OFF)
this DOESN’T…
Item RLHausAlle received update UP
According to the documentation, RECEIVED UPDATE can use an Attribute (UP or ON/OFF in These cases). Why does it work with the light, but not the rollershutter?
Probably I am not the only one using “-control” type things to be able to trigger on up/down & stop commands. In the past I noticed, that openHAB resends telegrams received for these items to the bus.
