Hi all,
I have installed the new knx binding and set up my test environment.
I get many warnings in the log:
2018-05-19 22:45:22.183 [WARN ] [net/IP Tunneling 192.168.178.72:3671] - response timeout waiting for confirmation
tuwien.auto.calimero.KNXTimeoutException: no confirmation reply received for 1.1.4->1/2/1 L_Data.req, low priority hop count 6 repeat, tpdu 00 00
at tuwien.auto.calimero.knxnetip.ClientConnection.doExtraBlockingModes(ClientConnection.java:244) ~[?:?]
at tuwien.auto.calimero.knxnetip.ConnectionBase.send(ConnectionBase.java:258) ~[?:?]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.send(KNXnetIPTunnel.java:178) ~[?:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.onSend(KNXNetworkLinkIP.java:243) ~[?:?]
at tuwien.auto.calimero.link.AbstractLink.send(AbstractLink.java:351) ~[?:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.sendRequestWait(KNXNetworkLinkIP.java:222) ~[?:?]
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.readFromGroup(ProcessCommunicatorImpl.java:418) ~[?:?]
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.read(ProcessCommunicatorImpl.java:346) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.readNextQueuedDatapoint(AbstractKNXClient.java:284) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.lambda$1(AbstractKNXClient.java:199) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
Config seems ok for me.
As a first suggestion, comment out Thing config (address, fetch, ping and read interval)
autoReconnectPeriod should be at least as long as responseTimeout, but for testing I would recommend 60 Seconds.
localIp should not be needed any longer.
And commented the things out, with following result:
2018-05-20 01:35:58.227 [WARN ] [ore.common.registry.AbstractRegistry] - Could not remove element: null
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.preserveDynamicState(ThingRegistryImpl.java:177) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.onRemoveElement(ThingRegistryImpl.java:158) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.onRemoveElement(ThingRegistryImpl.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.removed(AbstractRegistry.java:174) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.removed(AbstractRegistry.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:59) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:74) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutRemovedElement(AbstractProvider.java:82) ~[?:?]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.lambda$20(GenericThingProvider.java:773) ~[?:?]
at java.lang.Iterable.forEach(Iterable.java:75) ~[?:?]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.modelChanged(GenericThingProvider.java:775) ~[?:?]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:301) ~[?:?]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:139) ~[?:?]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:227) ~[?:?]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:291) ~[?:?]
at org.eclipse.smarthome.core.service.WatchQueueReader.lambda$3(WatchQueueReader.java:323) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
After that I uncommented the things and got again this null pointer exception, but no other warnings so far.
Edit: After a reboot I have again more warnings:
2018-05-20 01:50:45.753 [WARN ] [calimero.mgmt.TL 192.168.178.72:3671] - disconnected not gracefully (timeout)
tuwien.auto.calimero.KNXTimeoutException: no confirmation reply received for 1.1.4->1.1.3 L_Data.req, system priority hop count 6 repeat, tpdu 81
at tuwien.auto.calimero.mgmt.TransportLayerImpl.sendDisconnect(TransportLayerImpl.java:612) ~[?:?]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.disconnectIndicate(TransportLayerImpl.java:600) ~[?:?]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.disconnect(TransportLayerImpl.java:342) ~[?:?]
at tuwien.auto.calimero.mgmt.Destination.destroy(Destination.java:371) ~[?:?]
at tuwien.auto.calimero.mgmt.Destination.close(Destination.java:383) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementProceduresImpl.isAddressOccupied(ManagementProceduresImpl.java:311) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.isReachable(AbstractKNXClient.java:338) ~[?:?]
at org.openhab.binding.knx.handler.AbstractKNXThingHandler.pollDeviceStatus(AbstractKNXThingHandler.java:144) ~[?:?]
at org.openhab.binding.knx.handler.AbstractKNXThingHandler.lambda$1(AbstractKNXThingHandler.java:184) ~[?:?]
