Hallo,
I have the same Problem and I have no clue what I do wrong.
could you please post the settings you are using now?
Hallo,
Got the same problem.
Can you post your code ?
Please be more specific in question of “the same problem”, as I’m sure it’s not.
The whole problem above is… “It doesn’t work as suggested, although I did all correct” which can’t be true, as the Addon would work flawless if all is configured correctly
Please post your configuration (including information how you did the configuration, i.e. text file or UI)
Please be aware that the headline is about knx Binding 2.3, which is really outdated, and it’s very unlikely that you use this version at all (you can’t download this version since 2019 for a start…)
To be fair, most problems do not address a specific version at all (so it’s more a knx1 vs. knx2, vs. knx3 point).
You are 100% right. Sorry, my bad.
