Hi OpenHab,
I have dry contacts which indicate open/closed and in this case ON (True) indicates that item is closed and OFF (False) that item is opened.
Unfortunately there is no way using KNX binding to configure properly this scenario. I am using custom transformations to redefine OPEN to CLOSED and vice versa, but this seems like a hack… considering also that icons are the other way around…
Could we please consider adding a possibility to identify that contact channel on KNX thing can be inverted? So that there is no need to redefined anything in transformations and have iconset right.
Thanks!
