Hi all,
I am running Raspbian GNU/Linux 10 on a Raspberry Pi 3, and everything seems to work fine for a couple a days. After a few days openHABian does not react anymore and the following error occurs repeatedly in the log:
2021-03-12 19:57:40.246 [WARN ] [NXnet/IP Tunneling 192.168.1.50:3671] - response timeout waiting for confirmation
tuwien.auto.calimero.KNXTimeoutException: no confirmation reply received for 0.0.0->1.1.20 L_Data.req, system priority hop count 6 repeat, tpdu 81
at tuwien.auto.calimero.knxnetip.ClientConnection.doExtraBlockingModes(ClientConnection.java:244) [bundleFile:?]
at tuwien.auto.calimero.knxnetip.ConnectionBase.send(ConnectionBase.java:258) [bundleFile:?]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.send(KNXnetIPTunnel.java:177) [bundleFile:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.onSend(KNXNetworkLinkIP.java:264) [bundleFile:?]
at tuwien.auto.calimero.link.AbstractLink.send(AbstractLink.java:332) [bundleFile:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.sendRequestWait(KNXNetworkLinkIP.java:243) [bundleFile:?]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.sendDisconnect(TransportLayerImpl.java:627) [bundleFile:?]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.disconnectIndicate(TransportLayerImpl.java:608) [bundleFile:?]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.disconnect(TransportLayerImpl.java:342) [bundleFile:?]
at tuwien.auto.calimero.mgmt.Destination.destroy(Destination.java:371) [bundleFile:?]
at tuwien.auto.calimero.mgmt.Destination.close(Destination.java:383) [bundleFile:?]
at tuwien.auto.calimero.mgmt.ManagementProceduresImpl.$closeResource(ManagementProceduresImpl.java:238) [bundleFile:?]
at tuwien.auto.calimero.mgmt.ManagementProceduresImpl.isAddressOccupied(ManagementProceduresImpl.java:311) [bundleFile:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.isReachable(AbstractKNXClient.java:342) [bundleFile:?]
at org.openhab.binding.knx.internal.handler.AbstractKNXThingHandler.pollDeviceStatus(AbstractKNXThingHandler.java:148) [bundleFile:?]
at org.openhab.binding.knx.internal.handler.AbstractKNXThingHandler.lambda$1(AbstractKNXThingHandler.java:188) [bundleFile:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
2021-03-12 19:57:40.248 [WARN ] [calimero.mgmt.TL 192.168.1.50:3671 ] - disconnected not gracefully (timeout)
at tuwien.auto.calimero.knxnetip.ClientConnection.doExtraBlockingModes(ClientConnection.java:244) ~[bundleFile:?]
at tuwien.auto.calimero.knxnetip.ConnectionBase.send(ConnectionBase.java:258) ~[bundleFile:?]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.send(KNXnetIPTunnel.java:177) ~[bundleFile:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.onSend(KNXNetworkLinkIP.java:264) ~[bundleFile:?]
at tuwien.auto.calimero.link.AbstractLink.send(AbstractLink.java:332) ~[bundleFile:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.sendRequestWait(KNXNetworkLinkIP.java:243) ~[bundleFile:?]
I have the following KNX configuration in knx.things:
Bridge knx:ip:bridge "GIRA KNX/IP Gateway" @ "KNX" [
type="TUNNEL",
ipAddress="192.168.1.50",
portNumber=3671,
localIp="192.168.1.126",
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=60,
localSourceAddr="0.0.0"
Thing device da-1 "Dim Actor 1" @ "KNX" [
address="1.1.11",
fetch=true,
pingInterval=300,
readInterval=3600
Type dimmer : woonkamerCentraal "Woonkamer_Centraal_Dimmer" [ switch="1/3/3", position="1/3/6", increaseDecrease="1/3/4" ]
Type dimmer : woonkamerSpots "Woonkamer_Spots_Dimmer" [ switch="1/3/1", position="1/3/5", increaseDecrease="1/3/2" ]
Type dimmer : eetkamerSpots "Eetkamer_Spots" [ switch="1/2/1", position="1/2/15", increaseDecrease="1/2/2" ]
Type dimmer : eetkamerCentraal "Eetkamer_Centraal" [ switch="1/2/3", position="1/2/17", increaseDecrease="1/2/4" ]
Thing device da-2 "Dim Actor 2" @ "KNX" [
address="1.1.12",
fetch=true,
pingInterval=300,
readInterval=3600
Type dimmer : hal "Hal" [ switch="1/1/1", position="1/1/3", increaseDecrease="1/1/2" ]
Type dimmer : keukenSpots "Keuken_Spots" [ switch="1/2/5", position="1/2/16", increaseDecrease="1/2/6" ]
Type dimmer : keukenWand "Keuken_Wand" [ switch="1/2/7", position="1/2/19", increaseDecrease="1/2/8" ]
Type dimmer : keukenCentraal "Keuken_Centraal" [ switch="1/2/9", position="1/2/18", increaseDecrease="1/2/10" ]
Thing device da-3 "Dim Actor 3" @ "KNX" [
address="1.1.13",
fetch=true,
pingInterval=300,
readInterval=3600
Type dimmer : slaapkamerCentraal "Slaapkamer_Centraal" [ switch="3/1/1", position="3/1/3", increaseDecrease="3/1/2" ]
Thing device da-4 "Dim Actor 4" @ "KNX" [
address="1.1.14",
fetch=true,
pingInterval=300,
readInterval=3600
Type dimmer : slaapkamerBureau "Slaapkamer_Bureau" [ switch="3/1/7", position="3/1/9", increaseDecrease="3/1/8" ]
Type dimmer : badkamerSpots "Badkamer_Spots" [ switch="3/6/1", position="3/6/3", increaseDecrease="3/6/2" ]
Thing device da-5 "Dim Actor 5" @ "KNX" [
address="1.1.15",
fetch=true,
pingInterval=300,
readInterval=3600
Type dimmer : zone1 "Zone_1" [ switch="4/2/1", position="4/2/3", increaseDecrease="4/2/2" ]
Type dimmer : zone2 "Zone_2" [ switch="4/2/4", position="4/2/6", increaseDecrease="4/2/5" ]
Thing device da-6 "Dim Actor 6" @ "KNX" [
address="1.1.16",
fetch=true,
pingInterval=300,
readInterval=3600
Type dimmer : garageCentraal1 "Garage_Centraal_1" [ switch="5/1/1", position="5/1/3", increaseDecrease="5/1/2" ]
Type dimmer : garageCentraal2 "Garage_Centraal_2" [ switch="5/1/4", position="5/1/6", increaseDecrease="5/1/5" ]
Type dimmer : oprit "Oprit" [ switch="4/3/1", position="4/3/3", increaseDecrease="4/3/2" ]
Thing device da-7 "Dim Actor 7" @ "KNX" [
address="1.1.17",
fetch=true,
pingInterval=300,
readInterval=3600
Type dimmer : slaapkamerMees "Slaapkamer_Mees" [ switch="3/2/1", position="3/2/10", increaseDecrease="3/2/9" ]
Type dimmer : slaapkamerPleun "Slaapkamer_Pleun" [ switch="3/3/1", position="3/3/11", increaseDecrease="3/3/10" ]
Type dimmer : slaapkamerGies "Slaapkamer_Gies" [ switch="3/4/1", position="3/4/11", increaseDecrease="3/4/10" ]
Thing device sa-1 "Schakel Actor 1" @ "KNX" [
address="1.1.20",
fetch=true,
pingInterval=300,
readInterval=3600
Type switch : keukenKoffie "Keuken_Koffie" [ ga="1/2/14" ]
Thing device sa-2 "Schakel Actor 2" @ "KNX" [
address="1.1.21",
fetch=true,
pingInterval=300,
readInterval=3600
Type switch : badkamerSpiegel "Badkamer_Spiegel" [ ga="3/6/7" ]
Type switch : woonkamerStopcontact "Woonkamer_Stopcontact" [ ga="1/3/7" ]
Thing device sa-3 "Schakel Actor 3" @ "KNX" [
address="1.1.22",
fetch=true,
pingInterval=300,
readInterval=3600
Type switch : bergingCentraal "Berging_Centraal" [ ga="5/3/1" ]
The KNX gateway that I use is the Gira 216800 IP-interface KNX.
Does anyone recognise this problem and has some advice to help me with this?
Thanks in advance!
Kind regards,
Roel Cuppen
