KNX Binding needs daily reinstall
(Roland Wilke) #1
i migrated to knx binding 2.0 some time ago. Since two days the binding does not work anymore - until i reinstall it.
Then it works for a day or two and I need to reinstall again. Any ideas?
(Angelos) #2
does it get uninstalled without your intervention or you are uninstalling it and then re-installing it?
You need to post some logs and configs to see what could be wrong.
(Roland Wilke) #3
I reinstall manually. Today reinstalled - 4h later everything openhab works - but not KNX.
How do I get the log. Maybe I make a complete reinstallation of open hab…
(Angelos) #4
See here: https://www.openhab.org/docs/tutorial/logs.html
Maybe you have some leftover configs from the KNXv1 times which are causing “interference”
Check the logs for hints.
(Vincent Regaud) #5
@Dim, @Roland_Wilke
Maybe try clearing the cache
