Dear Friends,
I have been using openHAB2 on a MAC for a while and decided to move to a openhabian based install. After installing I have moved the userdata and the config as outlined in the backup chapter to the raspberry and started the install. Z-Wave and other things are working, however, KNX is not working anymore.
I get the following error:
Error Connecting to KNX bus: on connect to /10.2.4.21:3671
KNXnet/IP Tunneling 10.2.4.21:3671 communication failure on connect
and
Invalid argument (sendto failed)
I have checked the following:
- That the knx configuration is correct
- That I can reach the KNX Endpoint in the network
- That the setup still works with the MAC
Any advice how to move on? Maybe I just forgot something to install or other things are missing.
On checking I get the following information about KNX:
openhab> config:list "(service.pid=org.openhab.knx)"
Pid: org.openhab.knx
BundleLocation: mvn:org.openhab.binding/org.openhab.binding.knx/1.9.0
Properties:
autoReconnectPeriod = 10
ip = 10.2.4.21
port = 3671
service.pid = org.openhab.knx
type = TUNNEL
Does anyone have a hint for me?
Thanks a lot for this brilliant piece of software!!
David
