I installed Openhab 3 and activated the KNX binding.
I can also switch lights on and off via an item.
That means Openhab sends accordingly to the BUS.
What does not work, however, is if I turn the light on or off at the switch that Openhab receives the message.
For me this means that Openhab does not get the status of the Stauts group address.
I only see the information in the log file when I make changes directly from Openhab.
Does somebody has any idea?
If I trigger Telegrams by ETS, lamp also is working, but in the Logfile from OH I cannot see that something comes in.
The device is programmed as follows
UID: knx:device:CRU:25
label: KNX Device
thingTypeUID: knx:device
configuration:
pingInterval: 5
address: 0.0.0
readInterval: 5
fetch: false
bridgeUID: knx:ip:CRU
channels:
- id: sw_Arbeitszimmer
channelTypeUID: knx:switch
label: Deckenlicht Arbeitszimmer
description: null
configuration:
ga: 1/2/11+<1/2/12
UID: knx:ip:CRU
label: KNX/IP Gateway
thingTypeUID: knx:ip
configuration:
useNAT: false
readRetriesLimit: 3
ipAddress: 192.168.25.12
autoReconnectPeriod: 30
localIp: 192.168.25.14
type: TUNNEL
localSourceAddr: 0.0.0
readingPause: 50
portNumber: 3671
