hey there,
the problem is within the knx binding rasp pi2 and raspbian jessie:
it says :“knx interface wether /dev/ttys0 or /dev/ttyUSB0” but none of those exist. I only got /dev/AMA0, but that doesn’t seem to work.
knx:serialPort=/dev/ttyAMA0
ls -la /dev/tty* shows a lot of fancy tty’s, but no usb
do I need to install eibd? I hope not, the manual says that the knx binding does the job.
uh, seems like noone uses usb to knx binding… o.k. lets ask another way: the rasp pi2 has 4 usb ports, is that the reason why i can’t connect via ttyusb0?
any help appreciated. can i skrew something up with installing eibd-daemon only to test, if this helps?
two hours later… I found out that ttyama0 is the serial connector on top of the pi. that means the pi refuses to have usb ports >_< but i can clearly see four of them on the side of the pcb… but no /dev/ttyUSB* to see in linux. funny, cause all four ports are in use, and work.
