Hi Folks,
I have two OH instances working with knx bus. One OH1, and one OH2.
While OH1 with KNX 1 logs some great information about Problems:
2018-09-09 09:00:19.216 [ERROR] [tuwien.auto.calimero ] - [Timer-14] KNXnet/IP Tunneling 192.168.178.200:3671: establishing connection failed
tuwien.auto.calimero.exception.KNXRemoteException: error response from control endpoint /192.168.178.200:3671, could not accept new connection (maximum reached)
at tuwien.auto.calimero.knxnetip.ClientConnection.connect(ClientConnection.java:174) ~[na:na]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.<init>(KNXnetIPTunnel.java:117) ~[na:na]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.<init>(KNXNetworkLinkIP.java:180) ~[na:na]
at org.openhab.binding.knx.internal.connection.KNXConnection.connectByIp(KNXConnection.java:263) ~[na:na]
at org.openhab.binding.knx.internal.connection.KNXConnection.connect(KNXConnection.java:159) ~[na:na]
at org.openhab.binding.knx.internal.connection.KNXConnection$ConnectTimerTask.run(KNXConnection.java:483) ~[na:na]
at java.util.TimerThread.mainLoop(Timer.java:555) ~[na:1.8.0]
at java.util.TimerThread.run(Timer.java:505) ~[na:1.8.0]
OH2 with KNX 2 only provides me with some useless information:
2018-09-09 07:00:40.256 [ERROR] [et/IP Tunneling 192.168.178.200:3671] - establishing connection failed, null
Is it possible to configure OH2 to output information that leads to the problem?
Bests
Pascal
