first of all … i posted this twice, but as the other thread
is solved i started a new one …
Now,
probably you will say: “Dude! buy a new actor!!”, but I´ll try it anyway …
My Actor “Rollladenaktor 4fach 6 A 230V, Hand REG”
has in fact no response address of the shutter position.
Just Langzeit-/ Kurzzeit Betrieb.
When i give the Rollershutter Item the Langzeit Address, i can move it, but I can´t stop it…
When i give it the Kurzzeit Address it just moves in tiny steps…
Hi Wurzelseppi,
a couple of days ago Amazons Alexa arrived and the combination of openhab2 and all other switches is working well.
All, except the shutters! I’ve got the same problem and cannot find a solution. Did you get a response on your post how to trigger that Step-Object?
Are you living in Germany? (Habe das selbe Problem wie du, hoch/runter geht einwandfrei. Nur angehalten bekomm ich die Rolladen nicht über openhab)
Cheers
Dirk
For rollershutter items, you have to use both MOVE and STEP GA:
Rollershutter MyShutter "My Rollershutter" {knx="1/1/1,1/1/2"}
//1/1/1 -> MOVE UP/DOWN
//1/1/2 -> STEP UP/DOWN (here used as STOP)
As the actuator will not announce if it’s running the roller shutter up, down or stops it, there is no way to even guess at which hight the roller shutter is. But of course you can setup a rule to measure the run time as long as only openHAB does the control.
But I never implemented this, I swallowed the pill and bought 4 new actuators - for 19 roller shutters, a cinema screen and a motorized window…
