what does the + sign before a GA with KNX binding do?
I saw an configuration with {knx="+<2/7/5"} instead of {knx="<2/7/5"} - what is the difference? There is no explanation in the docs.
{knx="+<2/7/5"}
makes no sense!
the plus adds some more GA, with the same command logic (you have to read the whole docs on this):
Dimmer TestDimmer "TestDimmer [%s]" (Lights) { knx="1/3/20+0/3/20, 1/3/21, 1/3/22+0/3/22+0/8/15" }
this one tells the GA 1/3/20 and 0/3/20 the same time as OnOffType
, 1/3/21 as IncreaseDecreaseType
, and 1/3/22 and 0/3/22 and 0/8/15 as PercentType
read the “Example”-part again…
ok, thank you… the example was exact like written by me, so I think this was wrong
