KNX - cant turn switch on or off
Check this out:
There is a lot of info in that thread related to this topic.
Hi Dim,
Pysical adress is the same as individual adress?
if yes i changed it too 1.0.4. I couldn’t set it to 1.0.0.
I’m still reading the other thread about a dummy application
Yes. PA = IA (they are used as synonyms in KNX literature)
To change it to x.y.0 you will need to change your Backbone Line medium from TP to IP.
There is some info about this in the thread above.
HI,
thanks for all the help.
So i changed some settings and got it working. Then something happend and i wasn’t able to open the webinterface of openhab.
So after 2days of figuring it out, i decided to start over.
So after setting evrything back up.
I was able to turn the light on and off.
My configuration.
-----------------------services\knx.cfg----------------------------------
KNX gateway IP address
(optional, if serialPort or connection type ‘ROUTER’ is specified)
ip=192.168.0.112
Local KNX Binding bus address.
Use it, when two or more openHAB Instances are connected to the same KNX bus.
(optional, defaults to 0.0.0)
#busaddr=
Ignore local KNX Events, prevents internal events coming from
‘openHAB event bus’ a second time to be sent back to the ‘openHAB event bus’.
Note: To send back events second time is a Bug, but for backward compatibility, the behavior is not changed.
For new installations, its recommend to set “ignorelocalevents=true”
(optional, defaults to false)
KNX IP connection type. Could be either TUNNEL or ROUTER (optional, defaults to TUNNEL)
Note: If you cannot get the ROUTER mode working (even if it claims it is connected),
use TUNNEL mode instead with setting both the ip of the KNX gateway and the localIp.
type=TUNNEL
KNX gateway port (optional, defaults to 3671)
Note: If you use eibd, setting to 6720
port=3671
Local endpoint to specify the multicast interface, no port is used (optional)
localIp=192.168.0.132
-------------------items\encora.items----------------------------------
Switch lamp_vier “lamp 4” {knx=“0/0/4+0/0/14”}
Switch Dimmer_LEEN “dimmer lamp” {knx=“0/0/1”}
Dimmer Dimmer_een “Dimmer [%s]” {knx=“0/0/1, 0/1/0, 0/0/11”}
-----------------------sitemap\encora.sitemap---------------------
sitemap encora label=“lampVier”
Frame
Switch item=lamp_vier icon=“light” mappings=[OFF=“uit”, ON=“aan”]
Switch item=Dimmer_LEEN icon=“light” mappings=[OFF=“uit”, ON=“aan”]
Frame
Switch item=Dimmer_een label"lamp2 [%d %%]" mappings[INCREASE=“hoger”, DECREASE=“lager”]
Slider item=Dimmer_een label=“lamp [%d %%]”
The issues i have.
Issue 1: When i togle the switch it is sometimes slow.
Toggle on takes sometimes up to 5sec to turn on or off.
Also when the light is on and i refresh the page it doesnt show the correct state.
Issue 2: The dimmer works so on/off works and decrease and increase works.
But i can’t enter an 8 bit value trough the slider.
Am i doing something wrong?
I want to thank everyone for helping me.
Greetings
The dimmer does work now. But it is slow in response.
greetings,
It sounds to me that something is not optimized in your KNX installation side…
Since OH2 can connect with mode=TUNNEL and can control the endpoints, you may be experiencing delays due to some kind of KNX Bus issues. I can’t pin point the issue but it’s worth to try to analyze the telegram traffic using Bus Monitor with ETS.
Thank you for the support,
please can you help with configuration?
I have a Gira 2167, configured in ETS with the address 1.1.0
these are the info:
Device Info of Device 1.1.0
General
Item Value Resource name Unformatted value
Mask Version 091A 2330
Serial Number 0008:128104A5 DeviceSerialNumber 0008128104A5
Programming Mode Off ProgrammingMode false
Max. APDU Length 220 MaxApduLength 220
IP
Name KNX/IP router KNX/IP router
MAC Address 00-0A-B3-27-5C-07 000AB3275C07
IP Address 192.168.1.103 C0A80167
Subnet Mask 255.255.255.0 FFFFFF00
Default Gateway 192.168.1.1 C0A80101
Additional Addresses 1.1.15 1.1.16 1.1.17 1.1.18 4367 4368 4369 4370
Routing Multicast Address 224.0.23.12 E000170C
Line Coupler
Main > Sub Configuration Indiv. adressed: transmit always
Indiv. adressed repeat on error: repeat
Broadcasts: normal
Broadcast repeat on error: repeat
Group IACK: only if passed
Indiv. addressed IACK: normal MainLcConfig 117
Sub > Main Configuration Indiv. adressed: transmit always
Broadcasts: normal
Indiv. addressed IACK: normal SubLcConfig 117
Main > Sub Group Configuration Group addresses <= 0x6FFF (13/7/255): pass always
Group addresses >= 0x7000 (14/0/0): pass always
On transmission error: repeat MainLcGrpConfig 21
Sub > Main Group Configuration Group addresses <= 0x6FFF (13/7/255): pass always
On transmission error: repeat SubLcGrpConfig 21
Filter Table Load State Loaded GroupFilterTableLoadStatus 1
Coupler Service Control Inconsistency check: disabled
Heartbeat: disabled
SNA update: disabled
SNA read: enabled
Subline status: disabled CouplServControl 8
Max. Routing APDU Length 220 MaxRoutingApduLength 220
The application is on address 1.1.105
these are the info:
Device Info of Device 1.1.105
General
Mask Version 07B0 1968
Individual Address 1.1.105 IndividualAddress 4457
Device Manufacturer GIRA Giersiepen DeviceManufacturerId 8
Order Number $00000000000000000000 DeviceOrderId 00000000000000000000
Serial Number 0008:128104A6 DeviceSerialNumber 0008128104A6
Firmware Version [0] 0.1 FirmwareVersion 1
Bus Voltage 30,0V (±0.5V) DeviceBusVoltage 30
Application Program
Application program GIRA Giersiepen Applicazioni router V3.5 V3.5 ApplicationId 0008901A35
Load State Loaded ApplicationLoadStatus 1
Run State Running ApplicationRunStatus 1
Application Program 2
Application program 0 0000 V0.0 PeiprogId 0000000000
Load State Loaded PeiprogLoadStatus 1
Run State Running PeiprogRunStatus 1
Group Communication
Address Table Load State Loaded GroupAddressTableLoadStatus 1
Association Table Load State Loaded GroupAssociationTableLoadStatus 1
Group Object Table Load State Loaded GroupObjectTableLoadStatus 1
these are the ETS devices
1.1.0 Quadro Principale KNX/IP router V3.5 X X X X X GIRA Giersiepen 2167 00 KNX/IP router
1.1.1 Quadro Principale Camino/Caldai… Switch actuator,4 fold,universal X - X X X Video-Star 1A10xxA01R Switch actuator, 4 fold, universal
1.1.2 Quadro Principale Schalten, Treppenlicht 4f X X X X X MDT technologies AKS-0410.01 AKS-0410.01 Schaltaktor 4-fach, 4TE, 1…
1.1.3 Quadro Principale Switch actuator,4 fold,universal X X X X X Video-Star 1A10xxA01R Switch actuator, 4 fold, universal
1.1.4 Quadro Principale Switch actuator,4 fold,universal X X X X X Video-Star 1A10xxA01R Switch actuator, 4 fold, universal
1.1.5 Quadro Principale Dimmer 4 fold X X X X X Video-Star 1A04XXB03D KA/D 04.xx.1 4 fold dimmer
1.1.6 Quadro Principale Dimmer 4 fold X X X X X Video-Star 1A04XXB03D KA/D 04.xx.1 4 fold dimmer
1.1.7 Quadro Principale Dimmer 4 fold X X X X X Video-Star 1A04XXB03D KA/D 04.xx.1 4 fold dimmer
1.1.8 Quadro Principale Dimmer 4 fold X X X X X Video-Star 1A04XXB03D KA/D 04.xx.1 4 fold dimmer
1.1.9 Quadro Principale Dimmer 4 fold X X X X X Video-Star 1A04XXB03D KA/D 04.xx.1 4 fold dimmer
1.1.10 Quadro Principale Universal Interfaces, 4 fold X X - X X Video-Star 1M10xxC01K Universal Interfaces, 4 fold
1.1.11 Quadro Principale Logik, Zeitglied, Temperaturvergleich X - X X X MDT technologies SCN-LOG1.01 SCN-LOG1.01 Logikmodul, 2TE
1.1.12 Quadro Principale Riscaldamento Switch PWM 2067/0.1 X - - - X Schneider Electric Industries SAS MTN645129 Heizungsaktor REG-K/6x230/0,05A
1.1.13 Quadro Principale Tapparelle Jalousie, Rollade 8f 10 A X X X X X MDT technologies JAL-0810.01 JAL-0810.01 Jalousieaktor 8-fach, 8TE, …
1.1.14 Quadro Principale Tende Jalousie, Rollade 8f 10 A X X X X X MDT technologies JAL-0810.01 JAL-0810.01 Jalousieaktor 8-fach, 8TE, …
1.1.105 Quadro Principale Applicazioni router V3.5 X X X X X GIRA Giersiepen 2167 00 KNX/IP router
1.1.250 Quadro Principale iKnix ETS KNiX Port Gateway X X X X X iKNiX KNiX Port Gateway KNiX Port Gateway
PAPERUI Things configuration:
Configuration Parameters
Configure parameters for the thing.
IP Connection Type
Router
The ip connection type for connecting to the KNX bus. Could be either TUNNEL or ROUTER
Network Address
Network address of the KNX/IP gateway
Port
Port number of the KNX/IP gateway
Local Network Address
Network address of the local host to be used to set up the connection to the KNX/IP gateway
Local Device Address
The Physical Address (Individual Address) in x.y.z notation for identification of this KNX/IP gateway within the KNX bus
Use NAT
Set to “true” when having network address translation between this server and the gateway
Reading Pause
Time in milliseconds of how long should be paused between two read requests to the bus during initialization
Response Timeout
Seconds to wait for a response from the KNX bus
Read Retries Limit
Limits the read retries while initialization from the KNX bus
Auto Reconnect Period
Seconds between connection retries when KNX link has been lost, 0 means never retr
I connect the interface in ROUTER mode, it says ONLINE, and in the LOG i can see this:
2019-01-18 16:30:38.835 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.107’ to ‘2/2/2’ with value ‘[1]’
2019-01-18 16:30:39.558 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:08beb4b1 is disconnecting from the KNX bus
2019-01-18 16:30:39.614 [DEBUG] [nx.internal.client.AbstractKNXClient] - The KNX network link was detached from the process communicator
2019-01-18 16:30:39.668 [hingStatusInfoChangedEvent] - ‘knx:ip:08beb4b1’ changed from ONLINE to OFFLINE
2019-01-18 16:30:39.704 [me.event.ThingUpdatedEvent] - Thing ‘knx:ip:08beb4b1’ has been updated.
2019-01-18 16:30:39.713 [hingStatusInfoChangedEvent] - ‘knx:ip:08beb4b1’ changed from OFFLINE to OFFLINE (CONFIGURATION_ERROR): The ‘ipAddress’ of the gateway must be configured in ‘TUNNEL’ mode
2019-01-18 16:30:48.847 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:08beb4b1 is disconnecting from the KNX bus
2019-01-18 16:30:48.836 [me.event.ThingUpdatedEvent] - Thing ‘knx:ip:08beb4b1’ has been updated.
2019-01-18 16:30:48.868 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:08beb4b1 is connecting to the KNX bus
2019-01-18 16:30:48.871 [DEBUG] [binding.knx.internal.client.IPClient] - Establishing connection to KNX bus on 224.0.23.12:3671 in mode ROUTER.
2019-01-18 16:30:48.877 [hingStatusInfoChangedEvent] - ‘knx:ip:08beb4b1’ changed from OFFLINE (CONFIGURATION_ERROR): The ‘ipAddress’ of the gateway must be configured in ‘TUNNEL’ mode to UNKNOWN
2019-01-18 16:30:48.912 [hingStatusInfoChangedEvent] - ‘knx:ip:08beb4b1’ changed from UNKNOWN to ONLINE
2019-01-18 16:30:49.744 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.108’ to ‘2/0/5’ with value ‘[12, 41]’
2019-01-18 16:30:49.763 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.108’ to ‘2/2/3’ with value ‘[0]’
2019-01-18 16:30:51.586 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.109’ to ‘2/0/6’ with value ‘[7, -38]’
2019-01-18 16:30:51.606 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.109’ to ‘2/2/4’ with value ‘[0]’
2019-01-18 16:30:53.282 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.115’ to ‘3/1/7’ with value ‘[1]’
2019-01-18 16:30:56.586 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.47’ to ‘3/1/6’ with value ‘[1]’
So i assume that the connection is weel done, i read the knx bus broadcast telegram
BUT…
i can’t turn switch on or off..
ITEMS:
[16:38:37] openhabian@openHABianPi:/etc/openhab2/items$ cat knx.items
Switch BComSpecchio “Luce Specchio” [ “Lighting” ] { knx=“0/0/23+0/1/23” }
Switch BPadSpecchio “Luce Specchio Padronale” [ “Lighting” ] { knx=“0/0/30+0/1/30” }
Switch PadTestaSx “Testaletto sx” [ “Lighting” ] { knx=“0/0/25+0/1/25” }
Switch PadTestaDx “Testaletto dx” [ “Lighting” ] { knx=“0/0/26+0/1/26” }
SERVICES:
[16:40:54] openhabian@openHABianPi:/etc/openhab2/services$ cat knx.cfg
type=ROUTER
[16:41:00] openhabian@openHABianPi:/etc/openhab2/services$
Please, can you HELP?
some more logging:
2019-01-18 16:44:43.899 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to ‘Europe/Rome’.
2019-01-18 16:44:43.951 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to ‘40.6643757208513,14.806257176866714’.
2019-01-18 16:44:43.963 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to ‘it_IT’.
2019-01-18 16:44:44.309 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-01-18 16:44:44.815 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2019-01-18 16:44:59.965 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘knx.items’
2019-01-18 16:45:09.286 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-01-18 16:45:12.817 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘KNX.things’
2019-01-18 16:45:12.829 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘KNX.things’ is either empty or cannot be parsed correctly!
2019-01-18 16:45:14.173 [WARN ] [e.jetty.util.thread.ThreadPoolBudget] - Low configured threads: (max=8 - required=1)=7 < warnAt=8 for QueuedThreadPool[ServletModel-15]@d3ed2c{STARTING,8<=0<=8,i=0,q=0}[ReservedThreadExecutor@284ed9{s=0/1,p=0}]
2019-01-18 16:45:14.905 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.113:8080
2019-01-18 16:45:14.913 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.113:8443
2019-01-18 16:45:15.729 [hingStatusInfoChangedEvent] - ‘hue:bridge:0017880ae670’ changed from UNINITIALIZED to INITIALIZING
2019-01-18 16:45:16.648 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-01-18 16:45:17.685 [DEBUG] [org.openhab.binding.knx ] - BundleEvent STARTING - org.openhab.binding.knx
2019-01-18 16:45:17.693 [DEBUG] [org.openhab.binding.knx ] - BundleEvent STARTED - org.openhab.binding.knx
2019-01-18 16:45:17.783 [DEBUG] [org.openhab.binding.knx ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.profiles.ProfileAdvisor}={service.id=361, service.bundleid=206, service.scope=bundle, component.name=org.openhab.binding.knx.internal.profiles.KNXProfileAdvisor, component.id=217} - org.openhab.binding.knx
2019-01-18 16:45:17.856 [DEBUG] [org.openhab.binding.knx ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=362, service.bundleid=206, service.scope=bundle, component.name=org.openhab.binding.knx.internal.factory.KNXHandlerFactory, component.id=218} - org.openhab.binding.knx
2019-01-18 16:45:18.088 [hingStatusInfoChangedEvent] - ‘knx:ip:08beb4b1’ changed from UNINITIALIZED to INITIALIZING
2019-01-18 16:45:18.192 [hingStatusInfoChangedEvent] - ‘knx:ip:08beb4b1’ changed from INITIALIZING to UNKNOWN
2019-01-18 16:45:18.439 [DEBUG] [org.openhab.binding.knx ] - ServiceEvent REGISTERED - {org.openhab.binding.knx.KNXTypeMapper}={service.id=363, service.bundleid=206, service.scope=bundle, component.name=org.openhab.binding.knx.internal.dpt.KNXCoreTypeMapper, component.id=219} - org.openhab.binding.knx
2019-01-18 16:45:18.692 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:08beb4b1 is disconnecting from the KNX bus
2019-01-18 16:45:18.766 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:08beb4b1 is connecting to the KNX bus
2019-01-18 16:45:18.770 [DEBUG] [binding.knx.internal.client.IPClient] - Establishing connection to KNX bus on 224.0.23.12:3671 in mode ROUTER.
2019-01-18 16:45:19.027 [hingStatusInfoChangedEvent] - ‘hue:bridge:0017880ae670’ changed from INITIALIZING to OFFLINE: Hue bridge connection lost.
2019-01-18 16:45:19.467 [hingStatusInfoChangedEvent] - ‘knx:ip:08beb4b1’ changed from UNKNOWN to ONLINE
2019-01-18 16:45:19.993 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.108’ to ‘2/0/5’ with value ‘[12, 36]’
2019-01-18 16:45:20.304 [INFO ] [eemulation.internal.ConfigManagement] - Hue Emulation pairing disabled. Service available under /api
2019-01-18 16:45:21.570 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.109’ to ‘2/0/6’ with value ‘[7, -38]’
2019-01-18 16:45:26.377 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.10’ to ‘2/2/39’ with value ‘[0]’
2019-01-18 16:45:27.184 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.111’ to ‘2/0/2’ with value ‘[12, -115]’
2019-01-18 16:47:21.567 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.109’ to ‘2/0/6’ with value ‘[7, -38]’
2019-01-18 16:47:23.418 [ome.event.ItemCommandEvent] - Item ‘PadTestaDx’ received command ON
2019-01-18 16:47:23.501 [vent.ItemStateChangedEvent] - PadTestaDx changed from NULL to ON
2019-01-18 16:47:24.857 [ome.event.ItemCommandEvent] - Item ‘PadTestaDx’ received command OFF
2019-01-18 16:47:24.880 [vent.ItemStateChangedEvent] - PadTestaDx changed from ON to OFF
2019-01-18 16:47:27.181 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.46’ to ‘2/0/8’ with value ‘[18, 13]’
2019-01-18 16:47:27.204 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.111’ to ‘2/0/2’ with value ‘[12, -125]’
2019-01-18 16:47:27.225 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.111’ to ‘2/2/6’ with value ‘[0]’
2019-01-18 16:47:31.484 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.113’ to ‘2/0/1’ with value ‘[12, 66]’
2019-01-18 16:47:34.909 [TRACE] [nx.internal.client.AbstractKNXClient] - Received a Group Write telegram from ‘1.1.110’ to ‘2/2/5’ with value ‘[0]’
